Message 1 of 6
Returning BT equipment
Hi, I was sent a filter by BT which it turns out I don't need. Do I have to pay to return it?
Thank you
Angela
5 REPLIES 5
Message 2 of 6
Re: Returning BT equipment
Thank you
Angela
Not if its just a microfilter, as it would cost more to return it, that its worth.
Message 3 of 6
See link about returning BT equipment.
Note it is dependent on when you received your equipment whether or not you have to return it to BT.
https://www.bt.com/help/tv/how-to-return-and-recycle-your-bt-broadband-hub-and-bt-tv-box-fo
Message 4 of 6
Thank you very much
Message 5 of 6
@gg30340I don't think that applies to a DSL filter.🤣
@Angela6Keep hold of it you may need it in the future if you have connection problems.
Message 6 of 6
I am aware that it does not apply to filters but the bit about not going to the Post Office to return any equipment does apply.
