Message 1 of 3
Returns
New hub 6 arrived.On the back of the box it states to return old unit , clip on bt.com /Returns. It goes to info page then returns to another info page but gives no idea how to return the item.
2 REPLIES 2
Message 2 of 3
Re: Returns
If you've completed the minimum term you signed up for when you got the original hub, it's yours. Don't return it - it will do as a doorstop or a reserve if the HH6 fails, which is not exactly unknown.
Message 3 of 3
Re: Returns
Ok thanks
