Message 1 of 4
Rewards Card
I have just received my BT rewards card and have attempted 5 times to activate the card as instructed. I have filled in all the relevant info on the activation page but every time I fill in the password and try to activate nothing happens!!! Has anyone any ideas?
3 REPLIES 3
Message 2 of 4
Re: Rewards Card
@Val47 I'm sorry about that, you'll need to get in touch with Purecard about that via this link.
Message 3 of 4
Re: Rewards Card
All ok now. Sent e-mail to Purecard detailing problem and thought I would try one more time and lo and behold it worked. Whatever the problem was it is now sorted. Thanks for the quick response
Message 4 of 4
Re: Rewards Card
Hi @Val47 brilliant, I'm glad you got sorted Smiley Happy
