Lola
Newbie
Message 1 of 4
Ridiculous slow connection speed
It is taking 6mins from turning on my computer to connect to the Internet...........why so slow??? I've recently had two phone calls from BT trying to get me to change to BT Infinity and have refused, since then my connecting speed to the inernet has gone this slow.
3 REPLIES 3
Message 2 of 4
Re: Ridiculous slow connection speed
Hi Welcome to the forums
Here are some help pages done by CL Keith http://forumhelp.dyndns.org/speed/Speed.html
also post your full hub stats by entering 192.168.1.254 into your web browser address bar and navigate to adsl or use a-z, if netgear enter 192.168.0.1
Can you also post the full results from BT Speedtest speedtester.bt.com
Have you tried connecting to the test socket at the rear of the master socket  Test Socket.jpg
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
This is a customer to customer self help forum the only BT presence here are the forum moderators
Message 3 of 4
are you connecting to the router wireless or wired?  if wireless you can try downloading inssider2.1 (istumbler if MAC) and then run it. This will show the broadcasting networks round about you and their channels including your own. If you then enter your router and change your wireless channel to a free or less congested channel.
Moderator-Retired
Message 4 of 4
Are you sure it's the internet that's slow and not just your computer?
Dean
BTCare Community Mod
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side of the post.
