Message 1 of 9
Rounding up the minutes!
Spoke to BT the other day, only to find out that whenever you make a call, no matter how far into the next minute you are, they round it up to the next minute when calculating your usage. Think this is very very cheeky as I’m very sure technology can say exactly how many seconds you’ve used.
8 REPLIES 8
Message 2 of 9
Re: Rounding up the minutes!
Do you know any mobile operator that counts your mobile usage in seconds as against rounding up to next minute. All of mobile suppliers I have used apply same rules
Message 3 of 9
No they all count in minutes. What I’m saying is if you make. 10s call or even 1s they round that up to a minute used
Message 4 of 9
That is never going to happen
Message 5 of 9
What won’t?
Message 6 of 9
the mobile providers are not going to start checking usage in seconds
Message 7 of 9
But you think it’s okay to make a 1 second phone call and it be classed as a minute used?
Distinguished Guru
Distinguished Guru
Message 8 of 9
Where did he say he thought it was OK? Best not to shoot the messenger or you run out of messengers.
Message 9 of 9
Where did I say, I asked.
