jlp
Message 1 of 1
Router Aerials
I have read that most standard routers come with basic aeriels but that it is possible to buy better aeriels which can increase the signal, however I have been told by a friend that the bt hubs to not allow a change of aeriel, is this correct.  Also I understand aerials are rated by dBi, what is the rating of the aerial that came with the white hub? Thanks.
