Expert
Message 11 of 33
Re: Router Query
No. The router you mention has four LAN ports as well as wifi.
Message 12 of 33
Re: Router Query
No. It would be a router. It would handle your wireless and Ethernet connections.
Message 13 of 33
Re: Router Query
Have a look at the Asus DSL n66u, Billion 8800nl and the Draytek 2760n. If you read the reviews each has its own pros and cons. I am expecting to get infinity later this year and I'm still undecided which of those to go for.
Message 14 of 33
Re: Router Query
Thanks for info everyone
Message 15 of 33
Re: Router Query
Have had a look at the routers mentioned but like the sound of the hg612.my only concern is how easy is it to set up to use my existing router? Also is infinity2 VDSL or vdsl2?
Message 16 of 33
Re: Router Query
Infinity is VDSL2.  It is easy to set up your router. You need to go into the routers management pages and change the settings. It needs to be a PPPoE connection and the username needed is bthomehub@btbroadband.com If it asks for a password you can use anything.
Message 17 of 33
Re: Router Query
Just connect the WAN port on the Netgear to the modem and then set up as GG says, should be very straightforward.
Message 18 of 33
Re: Router Query
Just checked the ports on the netgear apart from the four LAN the other is labeled cable/fibre is this the equiv to the wan port mentioned?
Message 19 of 33
Re: Router Query
Message 20 of 33
Re: Router Query
