Message 1 of 33
Router Query
Hi looking for some advice please I've just upgraded to Infinity2 & everything seems fine but I wanted to use my Netgear dgn3700v2 instead of the hh5 but it's not compatible as it doesn't support VDSL apparently.Can someone please give me the best alternative router or is there a way I can use the netgear ?thanks
32 REPLIES 32
Message 2 of 33
Re: Router Query
you either need a vdsl modem/router or you need an openreach modem and then a router  modem/router are quite expensive and limited whereas getting an openreach modem form auction site and then router wouuld be a cheaper alternative
Message 3 of 33
Re: Router Query
You could use your netgear as a wirless acces point by connecting it to the HH5 but it is a bit of an adhoc solution as you can not just use the HH5 as a modem only.
If you buy an Openreach modem from an auction site for about £20 you could use your Netgear with the Openreach modem.
If you would rather have a one box solution just do a search for VDSL modem/router and you will find a selection. If you stick to the well known brands you won't go wrong.
Message 4 of 33
Re: Router Query
So can I get the open reach and use that with my netgear router? Thanks
Message 5 of 33
Re: Router Query
Excuse my ignorance are there different types of the open reach modems & if so which model would I require?thanks
Message 6 of 33
Re: Router Query
Just quickly checked and couple of different types: type a, type b and unlocked?
Message 7 of 33
Re: Router Query
most popular is HG612 and unlocked if you want to be able to see the stats - unlocked probably more expensive
Message 8 of 33
Re: Router Query
OK thank you are there any benefits in this setup as opposed to a single router/modem apart from price?
Message 9 of 33
Re: Router Query
having router and modem allows you to reset your router without disrupting your infinity connection
Message 10 of 33
Re: Router Query
Would I be right in assuming that the router would be a wireless access point only?
