HairyFool
Message 1 of 3
Router configuration options
Until now I have been using my own Netgear router as I had it before I took up BT broadband and it was set up as I needed it.
It has died (it was 5 years old) soI have tried to use the Home Hub 2 but that died within 2 days due to a failed ADSL modem. It has now been replaced with a Home Hub 3
Most of the tweaks I had with the Netgear were either not essential or I have been able to replicate with the home hub but with one exception.
I run a virtual test network behind its own address on a different subnet and I need to add a static route on the Home Hub yet I can find no option to do this.
DMZ does not achieve the same result.
2 REPLIES 2
pridmorej
Message 2 of 3
Re: Router configuration options
Hi,
Did you find a way of adding a static route?  Telnet?
I have a server with 2 NICs and need to set a static route to the internal network.  I had a Netgear router before and this was easy to setup.  However, I have just got BT Infinity, but no equivalent setting on the Home Hub 3.
Regards,
Jeremy
Message 3 of 3
@pridmorej wrote:
Hi,
Regards,
Jeremy
That person has not revisited the forum since. You may be better posting your own new question.
