Shadowjk
Message 1 of 2
Router crashes - Homehub 2
Hey , recently I have been having some problems with my router. It would just freeze and the wireless would cease from broadcasting so I cant connect and the Ethernet connection will not work. However if I restart the router It will work fine . I have changed the wireless channel and reset to defaults. I think It has something to do with TX Burst "overloading" the router however I am not certain yet
Any help Is appreciated,
Josh
1 REPLY 1
Shadowjk
Message 2 of 2
Re: Router crashes - Homehub 2
I don't normally bump threads but this is starting to drive me crazy. I have found out it only happens with my desktop which is wireless.
I did change the channel before and It worked wonders for about 2 months
