Message 1 of 12
Router hub 4 keeps disconnecting and restarting every 5 0r more times a day
HI MY HUB 4 ROUTER KEEPS DISCONNECTING AND RESTARTING  FLASHES ORANGE THEN GOES BLUE ABOUT 5 OR MORE TIMES A DAY.
I HAVE HAD THIS PROBLEM WITH AOL THEN TALKTALK AND NOW BT PHONE LINE CLEAR AND NO PROBLEMS,
IT'S JUST BROADBAND EVEN CHENGED FILLTER. ANY IDEAS
11 REPLIES 11
Message 2 of 12
Re: Router hub 4 keeps disconnecting and restarting every 5 0r more times a day
Hi Welcome to the community forums
Here is a basic guide to getting help from the community members done by CL Keith Please read through the link posted http://forumhelp.dyndns.info/speed/first_steps.html
once you have posted the information asked for then the community members can help you more
if using a hub 4 locate these lines located in the hub logs
Lines should look like this
19:11:29, 07 Nov. (2290101.460000) DSL noise margin: 7.00 dB upstream, 6.10 dB downstream
19:11:29, 07 Nov. (2290101.390000) DSL line rate: 448 Kbps upstream, 288 Kbps downstream
Thank You
This is a customer to customer self help forum the only BT presence here are the forum moderators
Please can you not use not use capitals as it is considered as shouting on a forum
Message 3 of 12
16:42:43, 15 Jun. ( 104.760000) DSL noise margin: 5.90 dB upstream, 20.90 dB downstream
16:42:42, 15 Jun. ( 103.540000) DSL line rate: 1159 Kbps upstream, 6648 Kbps downstream
Message 4 of 12
Due to all the disconnections / restarts of your hub  you are now in a banded profile you need to maintain a stable connection for 3/5 days and you will start to lift out of the banding automatically
Message 5 of 12
been doing this for over a week plus the router always on 24/7
Message 6 of 12
have you tried the quiet line test as explained in my link
Message 7 of 12
yes all clear
Message 8 of 12
suggest you try a hub factory reset
Message 9 of 12
done that to.
Message 10 of 12
ok it sounds like a faulty hub you need to call Customer services on 08001114567 and request a replacement
