pipersash
Message 1 of 4
Router log information
On my router log I found the following items.
wl1:A device <0E:FC:E0:13:D3:4A> failed to connect to SSID (Device/WiFi/SSIDs/SSID[WL_PRIV2G]) because it provided incorrect login information.
this appeared 131 times over an 8 hour period while we were not at home.
At the same time we found 10097 entries over a 4 day persiod that said:
BR_LAN:LAN Neighbor Discovery : Host 2a00:23c4:8a82:2000:c08c:ecc1:ab53:e99e is set inactive
BR_LAN:LAN Neighbor Discovery : Host fe80::750f:c8bd:1610:c85d is set inactive
BR_LAN:LAN Neighbor Discovery : Host 2a00:23c4:8a82:2000:c08c:ecc1:ab53:e99e is set active
BR_LAN:LAN Neighbor Discovery : Host fe80::750f:c8bd:1610:c85d is set active
This goes on at any time of the day.
Has anybody got any idea what these are or why this is happened.
With kind regards
Pipersash
Tags (1)
3 REPLIES 3
XRaySpeX
Recognised Expert
Message 2 of 4
Re: Router log information
Somebody is trying to connect to your router and failing. Anybody can try. Make sure you have a secure password. Check out your neighbours.
___________________________________________________________________________
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on left hand side
XRaySpeX
Recognised Expert
Message 3 of 4
Change your SSID and stop broadcasting it.
Keith_Beddoe
Message 4 of 4
