shaggy_x
Message 1 of 10
Router loses connection a lot during the day (and night)
My router is the latest Hub 5. throughout the day it will flash orange , lose connection, then reconnect a few minutes later. This happens a lot, at least once an hour and it's got to the point where I have to reset the router for it to get connection back again.
As part of my problem diagnosis I hard reset the router. This made he connection stable for a week or so then it was back to the usual connection drops again.
What else can I do as whenever I speak to bt it's just working off a script which has made no difference whatsoever .
9 REPLIES 9
Keith_Beddoe
Message 2 of 10
Re: Router loses connection a lot during the day (and night)
Welcome to this user forum.
Is there any noise on your phone calls? Dial 17070 and select option 2, there should be no noise between the announcements.
shaggy_x
Message 3 of 10
Thanks Keith
Just did a quiet line test and there's no noise
shaggy_x
Message 4 of 10
sorry I meant the router is the latest Smart Hub.
Keith_Beddoe
Message 5 of 10
Did you have a different router, like a HH5, before the smart hub?
shaggy_x
Message 6 of 10
Hi Keith
No this is the only bt router I've had .
I've been with bt infinity since August and before that was with sky (normal broadband)
Keith_Beddoe
Message 7 of 10
Thats a pity, as the HH6 seems to be giving people on this forum lots of similar problems.
If a factory reset fixes it for a while, I wonder if its a device that you have connected to the hub that is causing it?
shaggy_x
Message 8 of 10
Yes I noticed I'm not the only one . In the past few days I turned off smart setup, which made no difference and today I have changed wifi channels so let's see if that makes any difference.
Shame because I do get good speeds but too many disconnects, which is enough for me to want to move back to sky where I experienced zero connection dropouts in the 5 or so years I was with them
shaggy_x
Message 9 of 10
quick update
A couple of days ago I changed the wifi channels for both the bands to some random numbers from the list. SInce then the router has been connected and not one single drop.
Basically, disable smart channel select, then select your own channels manually.
So, something to consider if others are having similar issues.
Such a simple solution I'm surprised its not mentioned on here more often - although knowing me I've probably missed it 🙂
licquorice
Message 10 of 10
@shaggy_x wrote:
quick update
It is mentioned countless times on the forum. Smiley Happy Along with disabling smart setup and splitting the wireless frequencies.
