Sylvernitas
Message 11 of 30
Re: Router suddenly dropping sync
Here's some stuff:
DSL Status Up
DSL Modulation Mode ADSL2+
DSL Path Mode Fast
Downstream Rate 17048 kbps
Upstream Rate 947 kbps
Downstream Margin 3.0 db
Upstream Margin 5.9 db
Downstream Line Attenuation 19.1
Upstream Line Attenuation 7.1
Downstream Transmit Power 20.1
Upstream Transmit Power 12.6
PVC Connection
Encapsulation RFC 2364 PPPoA
Multiplexing VC
QoS UBR
PCR Rate 0
SCR Rate 0
Autodetect Disable
VPI 0
VCI 38
Enable Yes
PVC Status Down
Sylvernitas
Message 12 of 30
And today's logs. I'm going to leave it plugged into the test socket overnight and see what the logs are like in the morning.
2015/12/22 19:15:07 PPPOE authentication succeeded
2015/12/22 19:14:36 PPPOE Connection terminated.
2015/12/22 19:12:58 PPPOE Connection terminated.
2015/12/22 16:53:58 PPPOE authentication succeeded
2015/12/22 16:53:04 PPPOE Connection terminated.
2015/12/22 16:50:33 PPPOE authentication succeeded
2015/12/22 16:49:36 PPPOE Connection terminated.
2015/12/22 16:46:51 PPPOE authentication succeeded
2015/12/22 16:43:30 PPPOE Connection terminated.
2015/12/22 16:43:03 PPPOE authentication succeeded
2015/12/22 16:42:11 PPPOE Connection terminated.
2015/12/22 16:32:30 PPPOE authentication succeeded
2015/12/22 16:32:00 PPPOE Connection terminated.
2015/12/22 16:30:41 PPPOE Connection terminated.
2015/12/22 16:19:45 PPPOE authentication succeeded
2015/12/22 16:17:03 PPPOE Connection terminated.
2015/12/22 16:16:44 PPPOE authentication succeeded
2015/12/22 16:14:54 PPPOE Connection terminated.
2015/12/22 16:11:14 PPPOE authentication succeeded
2015/12/22 16:09:28 PPPOE Connection terminated.
2015/12/22 16:07:39 PPPOE authentication succeeded
2015/12/22 16:03:10 PPPOE Connection terminated.
2015/12/22 15:56:53 PPPOE authentication succeeded
2015/12/22 15:52:24 PPPOE Connection terminated.
2015/12/22 15:09:17 PPPOE authentication succeeded
2015/12/22 15:08:20 PPPOE Connection terminated.
2015/12/22 15:07:45 PPPOE authentication succeeded
2015/12/22 15:06:56 PPPOE Connection terminated.
2015/12/22 15:05:31 PPPOE authentication succeeded
2015/12/22 15:05:01 PPPOE Connection terminated.
2015/12/22 15:03:42 PPPOE Connection terminated.
2015/12/22 15:02:25 PPPOE authentication succeeded
2015/12/22 15:01:33 PPPOE Connection terminated.
2015/12/22 15:00:56 PPPOE authentication succeeded
2015/12/22 14:45:12 PPPOE Connection terminated.
2015/12/22 14:44:52 PPPOE authentication succeeded
2015/12/22 14:30:55 PPPOE Connection terminated.
2015/12/22 14:28:58 PPPOE authentication succeeded
2015/12/22 14:27:14 PPPOE Connection terminated.
2015/12/22 13:09:29 PPPOE authentication succeeded
2015/12/22 13:06:50 PPPOE Connection terminated.
2015/12/22 12:51:54 PPPOE authentication succeeded
2015/12/22 12:29:09 PPPOE Connection terminated.
2015/12/22 12:17:46 PPPOE authentication succeeded
2015/12/22 12:16:54 PPPOE Connection terminated.
2015/12/22 12:09:29 PPPOE authentication succeeded
2015/12/22 12:07:17 PPPOE Connection terminated.
2015/12/22 11:39:59 PPPOE authentication succeeded
2015/12/22 11:39:29 PPPOE Connection terminated.
2015/12/22 11:38:10 PPPOE Connection terminated.
2015/12/22 11:21:58 PPPOE authentication succeeded
2015/12/22 11:20:14 PPPOE Connection terminated.
2015/12/22 11:05:36 PPPOE authentication succeeded
2015/12/22 11:03:53 PPPOE Connection terminated.
2015/12/22 09:57:05 PPPOE authentication succeeded
2015/12/22 09:56:35 PPPOE Connection terminated.
2015/12/22 09:54:59 PPPOE Connection terminated.
2015/12/22 09:49:33 PPPOE authentication succeeded
2015/12/22 09:47:29 PPPOE Connection terminated.
2015/12/22 09:47:13 PPPOE authentication succeeded
2015/12/22 09:46:19 PPPOE Connection terminated.
2015/12/22 09:31:11 PPPOE authentication succeeded
2015/12/22 09:30:19 PPPOE Connection terminated.
2015/12/22 09:21:18 PPPOE authentication succeeded
2015/12/22 09:20:29 PPPOE Connection terminated.
2015/12/22 08:50:36 PPPOE authentication succeeded
2015/12/22 08:49:47 PPPOE Connection terminated.
2015/12/22 07:55:11 PPPOE authentication succeeded
2015/12/22 07:54:41 PPPOE Connection terminated.
2015/12/22 07:53:22 PPPOE Connection terminated.
2015/12/22 07:52:27 PPPOE authentication succeeded
2015/12/22 07:51:38 PPPOE Connection terminated.
2015/12/22 07:47:33 PPPOE authentication succeeded
2015/12/22 07:45:49 PPPOE Connection terminated.
2015/12/22 07:36:49 PPPOE authentication succeeded
2015/12/22 07:34:29 PPPOE Connection terminated.
2009/01/01 00:02:00 PPPOE authentication succeeded
SuperSajuuk
Message 13 of 30
No idea why your logs show PPPoE, as ADSL services are provisioned over PPPoA. Only a BT Infinity connection would use PPPoE, so it sounds like the router is just showing a bunch of failed efforts to use a technology that isn't used on ADSL.
Sylvernitas
Message 14 of 30
Yeah, that's odd. The log entries do correlate with when it drops connection though.
Sylvernitas
Message 15 of 30
OK, it's not the extension, same problem from the test socket.
I'm now connecting through my old BT Home Hub, and getting the same drop outs.
Speedtest while it's connected:
Ping: 18ms
Down: 15.8Mbps
Up: 0.97Mbps
(which is what I normally get, and am completely happy with).
Looking at the home hub stats, this doesn't look right:
Connection information
Line state: Connected
Connection time: 0 day, 00:05:09
Downstream: 18,463 Kbps
Upstream: 1,099 Kbps
ADSL settings
VPI/VCI: 0/38
Type: PPPoA
Modulation: G.992.5 Annex A
Latency type: Fast
Noise margin (Down/Up): 8,000.0 dB / 0.0 dB
Line attenuation (Down/Up): -1.4 dB / 2.9 dB
Output power (Down/Up): 16.0 dBm / 8.1 dBm
FEC Events (Down/Up): 0 / 0
CRC Events (Down/Up): 159 / 5
Loss of Framing (Local/Remote): 0 / 0
Loss of Signal (Local/Remote): 0 / 0
Loss of Power (Local/Remote): 0 / 0
Loss of Link (Remote): 0
HEC Errors (Down/Up): 10417 / 6
Error Seconds (Local/Remote): 0 / 0
Specifically, CRC events and HEC errors. Looks like I may have a line problem - it happens from the master socket with nothing else plugged in, and I've eliminated the router.
What's the best way to proceed with BT?
imjolly
Message 16 of 30
I would be more concerned with the -1.4db attenuation and the 8000db noise margin. I would go back to other router at least the stats looked ok
Sylvernitas
Message 17 of 30
LOL yeah, I think that's nonsense from when I copy'n'pasted it in. (the forum freaks out about invalid HTML and I have to go through Notepad). Here's the latest:
Connection time: 0 day, 00:06:46
Downstream: 18,499 Kbps
ADSL settings
VPI/VCI: 0/38
Type: PPPoA
Latency type: Fast
Noise margin (Down/Up): 3.1 dB / 5.3 dB
Line attenuation (Down/Up): 16.0 dB / 8.2 dB
Output power (Down/Up): 0.0 dBm / 12.1 dBm
CRC Events (Down/Up): 3 / 1
HEC Errors (Down/Up): 16 / 1
Error Seconds (Local/Remote): 0 / 1
imjolly
Message 18 of 30
That is a lot better. Now to see if it will hold connection
Sylvernitas
Message 19 of 30
Still drops every ten minutes or so. It just dropped while I was writing this...
While it's connected, it's really quick. Then, blam, it's gone. I wonder if the wind is blowing something around.
Do I have to talk to the people in India? I really struggle with call centres - I have very bad hearing at the best of times, add in a call to the other side of the world, and it's not going to go well.
Sylvernitas
Message 20 of 30
Overnight, it's stayed connected:
Connection time: 0 day, 08:39:11
Downstream: 16,148 Kbps
Upstream: 351 Kbps
ADSL settings
VPI/VCI: 0/38
Type: PPPoA
Latency type: Fast
Noise margin (Down/Up): 6.9 dB / 27.4 dB
Line attenuation (Down/Up): 16.5 dB / 8.5 dB
Output power (Down/Up): 0.0 dBm / 10.1 dBm
CRC Events (Down/Up): 1024 / 0
Loss of Framing (Local/Remote): 0 / 5
Loss of Signal (Local/Remote): 2 / 5
HEC Errors (Down/Up): 7443 / 0
Downstream is fine, but what's with that upstream bandwidth?
