orange_dude
Message 1 of 2
Router wireless disconnects
I've been having problems with my laptop disconnecting from the router.  I fix it by disconnecting from wireless then re-connecting and all is fine for a while.  I loaded a piece of software called Vistumbler to see what it reported.  I've attached a link to the graph.
BT Home Hub 5 (Type B) | Software version v0.07.06.01239-BT  | Last updated 7/3/2017
I've run Vistumbler on a separate laptop with the same effect so it is not the NIC.
I've pulled the plug from the router to DSL
I've rebooted the router
Any thoughts?
1 REPLY 1
orange_dude
Message 2 of 2
Re: Router wireless disconnects
forgot to say that I have ONE neighbour and their HH is on channel 1. I've tried every channel without success. I'm using 2.4Ghz as my laptop is old.
