naidis
Message 1 of 6
Router!!!
Hi guys i got problem with my bt hub 2.0 i have to restart my router many times a day because when it disconnects i cant connect to it back???
5 REPLIES 5
Message 2 of 6
Re: Router!!!
How are you connecting to it, wireless or direct Ethernet cable?
naidis
Message 3 of 6
Re: Router!!!
wireless
Message 4 of 6
Re: Router!!!
@naidis wrote:
wireless
Does it do it when you connect using an Ethernet cable?
naidis
Message 5 of 6
Re: Router!!!
no i dont use any cabels
Message 6 of 6
Re: Router!!!
None of the home hubs cope very well with wireless, if there is any form of interference, as its internal buffer overflows, while it tries to cope with all the re-transmissions.
You could try a different wireless channel with less interference on it.
See Wireless Help
Better still, connect using a direct Ethernet cable from the home hub to your computer.
There are some other alternatives here Network connections
