Message 1 of 13
Routers compatible with Fibre 2...
Hello; hope all are safe and well.
We have Fibre 2 at home - we need to replace the router with an unlocked/open one.
The one we have from BT is "Smart Hub 2" and want an unlocked one to replace it.
Please can you advise which is a very good one that is compatible?
Thank you very much.
M.
12 REPLIES 12
Message 2 of 13
Re: Routers compatible with Fibre 2...
Hi nearly any router with a WAN ethernet port should work fine. I use an Edgerouter 4 with Unifi Access Points, all good..
Message 3 of 13
That is like asking if somebody can recommend a car. Only you know your requirements and any VDSL modem/router will work. Have a look at the TP Link or Asus ranges for a device that meets your needs. Post back with the prospective choice for confirmation it is suitable if you wish.
Message 4 of 13
Err no, for Fibre 2 a VDSL modem/router is required.
Message 5 of 13
apologies I'm on a fttp connection.
Message 6 of 13
Let me share relevant pictures as well; so all can see what is there.
No option for attachments here; so here goes:
http://bit.ly/MyRouter1
bit.ly/MyRouter2nd
Take care.
Message 7 of 13
So you haven't got fibre2, you have full fibre (FTTP) in which case you only need a router with a WAN port as @@Kielty23 says, rather than a VDSL modem/router
Message 8 of 13
Why have you connected the DSL socket on the hub when you have FTTP?
Message 9 of 13
I believe Fibre 2 is available over fttp and as @licquorice states I don't think you should have the DSL socket connected too..
Message 10 of 13
I just wish BT would name products sensibly and call them by the technology they use!! As far as I'm aware, FTTP products are called Full Fibre xxxx, but they've probably changed it again this week.
