craigski
Message 21 of 30
Re: Routing to Gradwell at www.gradwell.com
Have just tried from a BT Retail Residential and works fine from 86.155.x.x address, so it seems to only affect BT Retail bsuiness customers so far.
pippincp
Sage
Message 22 of 30
As previously advised, take it up with BT Business.
ray_dorset
Distinguished Guru
Message 23 of 30
I can access those sites without a problem.
If not, I'll try again 🙂
craigski
Message 24 of 30
As requested, updated on BT business forums:
https://business.forums.bt.com/t5/Broadband-and-internet/BT-customers-can-t-access-our-websites-neit...
Ray - I assume you are using a BT residential service? What are the first 2 numbers of you public IP address?
pippincp
Sage
Message 25 of 30
From a reply to your post over there.
"The only thing that I can think of is that Gradwell are possibly blocking a certain range of IP addresses."
That is a possibility.
ray_dorset
Distinguished Guru
Message 26 of 30
The first digits are 86
pippincp
Sage
Message 27 of 30
And?
craigski
Message 28 of 30
It seems the BT/Gradwell firewall issues have been resolved.
It would appear that 81.x.x.x networks (mostly BT business??) were denied access to gradwell networks, however I have been informed that this is now resolved. Ray could access OK because he was on a BT 86.x.x.x network.
ray_dorset
Distinguished Guru
Message 29 of 30
So it was a Gradwell firewall issue?
licquorice
Message 30 of 30
Oh dear!!
