Newbie
Message 11 of 27
Re: Rural-ish broadband worse than dial up
The first time I tried that earlier it was red, this time it is green. I didn't get a screen shot the first time as I was clicking about.
Message 12 of 27
Your diwnload speed is very low for your connection speed but this could be caused by a low profile due to connection problems but without the diagnostic test results i cannot be sure.  It is the only test that shows the profile
you are on adslmax and you upstream speed and upload speed appear correct
Message 13 of 27
Profile looks ok from test but download speed very low. Are there any problems shown here for your exchange as it looks like congestion http://usertools.plus.net/exchanges/mso.php
http://usertools.plus.net/exchanges/?
http://btbusiness.custhelp.com/app/service_status
http://bt.custhelp.com/app/answers/detail/a_id/15036
http://community.plus.net/exchange-information/
Newbie
Message 14 of 27
Results: Whitchurch (Bucks)
Code:SMWTC
County:Buckinghamshire
Enabled:17 Dec 2003
Market:1
Mkt2014:A
Colour: Green20CN VP capacity at this exchange is currently showing as Green.
Click here for further details
Colour: RedBT have not advised a planned date for WBC on 21CN
Colour: UnknownYou can view recent Service Outages for this exchange here
Colour: UnknownBT have published Max DSL upgrade information for this exchange
Bookmark this exchange here
Back to exchange search
Newbie
Message 15 of 27
So you think its congestion? This isn't just today, and its not just one time of the day (although it is /slighty/ better at midnight), but its just as usuable from 9am to midnight.
Guru
Guru
Message 16 of 27
sksamuel,
Have you tried a speedtest with a Wired Ethernet connection to see if it's a WiFi issue?
jac_95 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
Message 17 of 27
Can you post the router 2lines of stats now you are in the test socket. If btspeedtester was not done wired then can you run wired as i previously asked and as asked by jac_95
Newbie
Message 18 of 27
No to be honest I haven't but I have tried a wi-fi repeater, I'm on 5 bars signal, and I've used a wifi analyzer to check the channels. We also get the same slowness on the other pcs. I have ordered a network cable and I'll test it with that tomorrow.
Also the other people in the village all said the internet is rubbish, although I assumed they meant no netflix or online games. It just took 30 seconds for the bbc news home page to load - it takes under 1 second on a `normal` connection. Are we just too far from the exchange?
To re-iterate I'm happy with the download speed when it works. All I want to do is browse webpages effectively, I don't care about streaming video etc.
I hope BT Infinity wil change this (our exchange says CS June 2014), although I wonder if this village won't be eligable.
Message 19 of 27
You have a 5mb connection and correct profile so should stream ok.  Wholesale won't help unless btspeedtester shows a priblem run with a cable not wireless
enter your phone number here. https://www.btwholesale.com/includes/adsl/main.html
Newbie
Message 20 of 27
I've moved my computer closer to the router so I can use the short cable I already have.
Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)Availability Date
ADSL MaxUp to 2.5--1.5 to 3.5Available
Fixed Rate2----Available
Will re-run the tests now.
