Message 1 of 7
S/N Ratio BT vs Talktalk
I have both BT and Talktalk broadband on two seperate phone BT lines with the copper wires going into the same pole and to the same exchange about 3 miles away.
The S/N figures for the two lines are completely different:
BT Up 6.3db  Down 5.2db
Talktalk Up 11.1db Down 11.6db
Is this likely to be down to the quality of the respective ISPs equipment in the exchange or some problem with the copper on one of the lines (the BT one)?
6 REPLIES 6
Message 2 of 7
Re: S/N Ratio BT vs Talktalk
no two pairs of copper are the same and the difference in noise margin is very little from your figures
Message 3 of 7
1db of line noise is nothing to worry about.
As imjolly says, no 2 are different. One might have a slightly worse joint somewhere or something like that.
Message 4 of 7
Hi TT tend to default noise margin to 12db to improve stability i know quite a few of there customers and they are all on 12db
Message 5 of 7
Sorry chaps I think you are missing the point of my question
BT = 6.3db   Talktalk 11.1db
I know it is a long time since I went to school and did logs but I think in absolute terms this is a factor of 3
Message 6 of 7
Sorry you're right, I misread.
As John has stated though, it's probably that talk talk have the target SNR margin at a higher value to improve stability on the circuit.
If your BT line is stable, then it's the talk talk line that needs to have the SNR reduced. But this might bring about instability on the line.
Message 7 of 7
like webby I misread your post sorry
then problwem is as john46 suggests
