Message 1 of 6
SALT Test
I've just dialled 175 from my phone and got the line test facility - not 17070, but it reads your number, you hang up and it calls back 30 seconds or so later. I thought this had been phased out when the switch from System X to 21CN happened.
5 REPLIES 5
Message 2 of 6
Re: SALT Test
The SALT (Subscribers Automatic Line Test) is something I have not heard about for a very long time. It surprises me that it still works on your exchange.
See http://www.gbnet.net/net/uk-telecom/p3-15.html
What is the number that will dial my 'phone back to test the ringing?
Dialling 174 on modern electronic exchanges.will make the exchange ring back when you put the phone on hook.
On a System X/Y dialling 177 will make the exchange read out your number, and dialling 175 will produce the exchange test...
 A replacement for both 174 and 175 has also been mentioned, which is
17070
Ringing 17070 results in
 "This circuit is defined as <number> "   and then   " BT line test
   facilities, please press 1 for ring-back test or clear down."
 Keying 1 then results in
 "BT ring-back test, please clear down."
 After a few seconds, phone rings, and announcement is
 "BT ring-back test completed."
Message 3 of 6
Re: SALT Test
When I rang 177 there was silence for about 30 seconds then it did "please hang up and try again", which was almost the same thing the first time I did 175, however it then went into reading the number etc. However when I ring 175 now there is no wait and it goes straight into line test, which would point towards some sort of initialisation first time round. I wonder whether 175 works on your line, Keith, with a wait of about 30 seconds when you ring?
Message 4 of 6
Re: SALT Test
P.S. Thanks for the link - very interesting. I'll have to test some of the codes.
Message 5 of 6
Re: SALT Test
No, I just get number not recognised.
Message 6 of 6
Re: SALT Test
Would this be a sign that I'm on System X equipment?
