Message 1 of 3
SBG3300
Hi all
Got my 3300 at the weekend speeds  definitly appear quicker on BT wholesale,
but I am concerned by my interleaving depth, Just wondered if anybody knows
how  I may be able to reduce it.
Dated 15 Jul 2014 19:02:03 DSLAM/MSAN type: IFTN:0xb203 / v0xb203 Modem/router firmware: AnnexA version - A2pv6F038n.d24i DSL mode: VDSL2 Status: Showtime Uptime: 1 day 12 hours 50 min 53 sec Resyncs: 0 (since 15 Jul 2014 10:18:32) Downstream Upstream Line attenuation (dB): 23.2 0.0 Signal attenuation (dB): Not monitored Connection speed (kbps): 46091 7246 SNR margin (dB): 6.1 6.0 Power (dBm): 12.3 4.9 Interleave depth: 1133 91 INP: 5.00 2.50 RSCorr/RS (%): 0.0279 0.0045 RSUnCorr/RS (%): 0.0004 0.0000 ES/hour: 0.92 0 ============================================================================ VDSL Training Status: Showtime Mode: VDSL2 Annex B VDSL Profile: Profile 17a Traffic Type: PTM Mode Link Uptime: 0 day: 0 hour: 12 minutes ============================================================================ VDSL Port Details Upstream Downstream Line Rate: 7.218 Mbps 46.130 Mbps Actual Net Data Rate: 7.198 Mbps 46.040 Mbps Trellis Coding: ON ON SNR Margin: 6.2 dB 6.2 dB Actual Delay: 8 ms 12 ms Transmit Power: 4.9 dBm 12.2 dBm Receive Power: -7.8 dBm -14.4 dBm Actual INP: 2.5 symbols 5.0 symbols Total Attenuation: 12.9 dB 26.7 dB Attainable Net Data Rate: 7.233 Mbps 55.900 Mbps ============================================================================ VDSL Band Status U0 U1 U2 U3 D1 D2 D3 Line Attenuation(dB): 3.6 37.7 56.1 N/A 17.9 46.1 71.9 Signal Attenuation(dB): 3.5 37.6 54.6 N/A 24.6 45.8 73.5 SNR Margin(dB): 7.3 6.1 6.2 N/A 6.3 6.1 6.3 Transmit Power(dBm):- 4.4 - 5.3 4.0 N/A 10.1 7.4 0.5 ============================================================================ VDSL Counters Downstream Upstream Since Link time = 12 min 45 sec FEC: 7582 0 CRC: 0 0 ES: 0 0 SES: 0 0 UAS: 0 0 LOS: 0 0 LOF: 0 0 LOM: 0 0 Latest 15 minutes time = 13 min 10 sec FEC: 7582 0 CRC: 0 0 ES: 0 0 SES: 0 0 UAS: 24 24 LOS: 0 0 LOF: 0 0 LOM: 0 0 Previous 15 minutes time = 0 sec FEC: 0 0 CRC: 0 0 ES: 0 0 SES: 0 0 UAS: 0 0 LOS: 0 0 LOF: 0 0 LOM: 0 0 Latest 1 day time = 13 min 10 sec FEC: 7582 0 CRC: 0 0 ES: 0 0 SES: 0 0 UAS: 24 24 LOS: 0 0 LOF: 0 0 LOM: 0 0 Previous 1 day time = 0 sec FEC: 0 0 CRC: 0 0 ES: 0 0 SES: 0 0 UAS: 0 0 LOS: 0 0 LOF: 0 0 LOM: 0 0 Total time = 13 min 10 sec FEC: 7582 0 CRC: 0 0 ES: 0 0 SES: 0 0 UAS: 24 24 LOS: 0 0 LOF: 0 0 LOM: 0 0 ============================================================================
Thanks for looking.
MikeSmiley Happy
2 REPLIES 2
Expert
Message 2 of 3
Re: SBG3300
@miked1963 wrote:
Hi all
Thanks for looking.
MikeSmiley Happy
The only way to get your interleave depth improved is to leave the modem constantly connected and pray that DLM sees your connection is more stable, then if this happens, it should slowly release the constraints it has placed on your line.
Note that this could take a while; as far as I am aware, DLM needs to see a stable line for around 10 days before it starts to relent and then it could be even longer after that, before you see anything noticable with regards to latency, etc as DLM acts in "steps", depending on where it's current position is on your line.
Message 3 of 3
Re: SBG3300
Thanks I guess I'll have to wait and see if this router makes my line more stable,
Thanks again.
Mike
