Newbie
Message 1 of 3
SCART connection compatibility
Hi - I have an old Sony television which I am currently not wanting to replace.... Just need to know which boxes would be compatible with it... Ideally would like to sign up for the 1 terabyte Total Entertainment package but need to know whether the box has SCART compatibility and if not is there an easy solution? Thank you!
2 REPLIES 2
Distinguished Guru
Distinguished Guru
Message 2 of 3
Re: SCART connection compatibility
The only 1TB Youview+ box supplies is the Ultra HD box  (DTRT4000) and your line  would need to have a sufficient  speed Infinity broadband connection for the UHD service for BT to supply it to you.
The  DTRT4000 does not have a Scart output.
The DTR-2100 500G Youview+  box has HDMI Scart and composite video outputs
The non recordable zapper Youview box has HDMI only.
There have been discussions on the Youview community  about using old TV's with Youview boxes without Scart output eg :
https://community.youview.com/youview/topics/cable-connections-hdmi-to-scart
Newbie
Message 3 of 3
thank you, very helpful! 🙂
