Oldsalt
Message 11 of 13
Re: SD Channels interference.
Last night I tried a test. Over night I left the Youview box switched off from the power supply, so it would have a cold start in the morning.
This morning when everything was powered up, I had perfect viewing, no interference or pixels. After 3.5 hours the interference returned again. Now I think I can safely assume it is the Youview box at fault.
Now for the battle over the phone!!!!
David
PaddyB
Moderator
Moderator
Message 12 of 13
Hi Oldsalt,
It does sound like a bit of a strange one that the interference is intermittent. I'd like to take a look at this for you and run a few check on your YouView box. Please can you send me in your details using the "Contact The Mods" link found in my profile.
PaddyB
Oldsalt
Message 13 of 13
I have had an enginer visit this morning, arranged by BT Consumer Help. He found nothing obviously wrong. The building I live in has a communial antenna which is not a normal style aerial, but is a vertical single rigid pole (no idea of it's correct name). He suggested I purchase a booster as it appears the signal strength is dipping below 75%.
I will give that a try as a booster is not expensive.
