Message 1 of 3
SH devices.
Smart Hub manager ->My devices.
How long do the entries stay live in that list? Do the entries ever timeout or just keep running cumulative totals however long logins are apart?
2 REPLIES 2
Message 2 of 3
Re: SH devices.
Hi @pbwpu   I would imagine it depends on your Lease Time setting. I have mine set to 21 days. You will find the setting in the Smart Hub Manager (192.168.1.254) -> Home -> Advanced Settings-> My network -> IPv4 Configuration. Of course I could be completely wrong. If you want to refresh the list then Factory Reset your Smart Hub If the [Remove] button doesn’t work.
Message 3 of 3
Re: SH devices.
I'll have a look at that thanks. I'm assuming they never remove atm but some confirmation would be ideal.
