Panda360
Message 1 of 19
SLOW Broadband please help??
Ok so just recently upgraded to option 3 broadband (was option 2), and the homehub 2. Been having really poor internet download speeds, and on speedtests struggling to get over 0.5/1.0meg download speed. And before you ask i have been connected for over 2 weeks, although the router is not showing that because i recently done a reset to see if it made any difference here are my router details speedtest results.
ADSL line status
Connection Information
Line stateConnected
Connection time1 days, 10:34:27
Downstream8,128 Kbps
Upstream448 Kbps
ADSL Settings
VPI/VCI0/38
TypePPPoA
ModulationG.992.1 Annex A
Latency typeInterleaved
Noise margin (Down/Up)9.1 dB / 26.0 dB
Line attenuation (Down/Up)15.8 dB / 6.0 dB
Output power (Down/Up)13.9 dBm / 1.9 dBm
Loss of Framing (Local/Remote)0 / 0
Loss of Signal (Local/Remote)0 / 0
Loss of Power (Local/Remote)0 / 0
FEC Errors (Down/Up)87 / 2
CRC Errors (Down/Up)13 / 1
HEC Errors (Down/Up)381 / 0
Error Seconds (Local/Remote)10 / 1
btspeedtest to follow
18 REPLIES 18
Message 2 of 19
Re: SLOW Broadband please help??
router may have been connected for 2 weeks but uptime is really what counts.  your connection is 8mb and looks ok.  did you run btspeedtester?
there also a lot of major outage problems affecting the whole country from time to time over the last few days
Marliedog
Newbie
Message 3 of 19
Have you had a read through the other threads about the slow internet speeds alot of us are experiencing?
You might find some useful tips in some of them, although there does seem to be a problem somewhere along the line. No pun intended.
Panda360
Message 4 of 19
speedtest results
Results Image not loaded
Test1 comprises of Best Effort Test: -provides background information.
Download  Speed
3886 Kbps
0 Kbps7150 Kbps
Max Achievable Speed
 Download speedachieved during the test was - 3886 Kbps
 For your connection, the acceptable range of speeds is 600-7150 Kbps.
 Additional Information:
 Your DSL Connection Rate :8128 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
 IP Profile for your line is - 7150 Kbps
If you wish to discuss these results please contact your ISP.
If you are experiencing problems with specific applications, servers or websites please contact your ISP for assistance.
Your test has completed please close this window to exit the performance tester.
this is the fastest its been for the last 2 weeks?!?! but i bet tomorrow it will drop out again or by tonight!! just when i want to go on xbox live!!
will test again later
Panda360
Message 5 of 19
this speed test is what i normally get what a pile of **bleep**e!!!!
FAQ
This Test comprises of Best Effort Test: -provides background information.
Download  Speed
598 Kbps
0 Kbps7150 Kbps
 Download speedachieved during the test was - 598 Kbps
This test was not conclusive and further testing is required.This might be useful for your ISP to investigate the fault.
If you wish to carry out further tests,please click on 'Continue' button.If not, please close the window using 'Exit' button and contact your ISP for further assistance with these results.
Please visit FAQ section if you are unable To understand the test results.
598k wtf ??? testing my head now?
Tags (1)
Panda360
Message 6 of 19
ADSL line status
Line stateConnected
Connection time3 days, 06:42:51
Upstream448 Kbps
ADSL Settings
VPI/VCI0/38
TypePPPoA
Noise margin (Down/Up)9.0 dB / 26.0 dB
FEC Errors (Down/Up)182 / 8
Panda360
Message 7 of 19
someone please help with this its doing my head in!!!!!!!! still painfully slow!!
Panda360
Message 8 of 19
FAQ
Download  Speed
689 Kbps
0 Kbps7150 Kbps
 Download speedachieved during the test was - 689 Kbps
Panda360
Message 9 of 19
ADSL line status
Line stateConnected
Connection time0 days, 00:29:43
Upstream448 Kbps
ADSL Settings
VPI/VCI0/38
TypePPPoA
Noise margin (Down/Up)9.5 dB / 26.0 dB
Line attenuation (Down/Up)15.7 dB / 6.0 dB
FEC Errors (Down/Up)1 / 0
CRC Errors (Down/Up)1 / 0
HEC Errors (Down/Up)0 / 0
Error Seconds (Local/Remote)1 / 0
Message 10 of 19
sorry to ask but can you post the adsl stats from your router and run btspeedtester http://speedtester.bt.com and post the results so we can compare them to your previous posts.
beat me to it  lol
