BREAKTIMES
Message 1 of 5
SLOW UPLOAD SPEED
Hi
Help req on my new installation of bt infinity1 38Mb  fttc,connected on 26th Nov
my download speed is 37.1-38.27 steady.but upload is only .1 TO.28, but have confirmation that would be getting 8-10 mb,which was one of the reasons I signed up to service.only got a fews left to cancel if problem not solved
I have resarted hh5 and ran bt help and cleaned my computer still the same
Hope you can help
BREAKTIMES
4 REPLIES 4
Gribley
Message 2 of 5
Re: SLOW UPLOAD SPEED
You`ll need to look into your hub and get the following from "toubleshooting"/"helpdesk".  The chaps here will try to help but it is just a user level forum not BT support 😞
This is mine for example (But I get poo speeds as well 0.something is usual for me as well)
6. Data rate:18144 / 62022
7. Maximum data rate:17708 / 61235
8. Noise margin:5.5 / 6.0
9. Line attenuation:20.0 / 16.6
imjolly
Message 3 of 5
run btspeedtester and when first test completes then run diagnostic test and post results - should be done wired nor wireless
btspeedtester
enter your phone number and post results  remember to delete number  https://www.btwholesale.com/includes/adsl/main.html
BREAKTIMES
Message 4 of 5
THANKS
HOPEFULLY DONE THIS RIGHT
1. Best Effort Test: -provides background information.
Download Speed
  1.
0 Mbps
38.72 Mbps Max Achievable Speed
 Download speedachieved during the test was - 38.06 Mbps  For your connection, the acceptable range of speedsis 20 Mbps-38.72 Mbps .  Additional Information:  IP Profile for your line is - 38.72 Mbps
2. Upstream Test: -provides background information.
Upload Speed
  1. 25 Mbps
Upload speed achieved during the test was - 0.25Mbps  Additional Information:  Upstream Rate IP profile on your line is - 10 Mbps
We were unable to identify any performance problem with your service at this time. It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly. If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
Please visit the FAQ if you are unable to understand the test results.
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
Availability Date
High
Low
High
Low
FTTC Range A (Clean)
80
80
20
20
Available
FTTC Range B (Impacted)
80
63.1
20
8.1
Available
ADSL Max
Up to 4
3 to 7
Available
Fixed Rate
2
Available
Other Offerings
Fibre Multicast
Available
BREAKTIMES
Message 5 of 5
THESE ARE READINGS FROPM HOME HUB 5
FORGOT LAST TIME
1. Product name:
BT Home Hub
2. Serial number:
+068543+NQ43115825
3. Firmware version:
Software version 4.7.5.1.83.8.173.1.6 (Type A) Last updated Unknown
4. Board version:
BT Hub 5A
5. VDSL uptime:
1 days, 18:40:22
6. Data rate:
8495 / 39997
24988 / 104790
8. Noise margin:
19.7 / 19.4
0.0 / 6.6
10. Signal attenuation:
0.0 / 6.6
11. Data sent/received:
269.2 MB / 2.6 GB
12. Broadband username:
bthomehub@btbroadband.com
13. BT Wi-fi:
No
