Message 1 of 1
SMART HUB 2 WIFI QUESTION
I have BT arriving tomorrow and installing FIBRE to Premises 100 with the 140 / 30 speeds.
I currently have the old router and can get 70 WIFI speed downstairs and 62 upstairs, no discs or extenders required.  I also have a WIFI camera outside that pics up signal too (although signal is lowest here).
I have been reading horror stories tonight about wifi problems on the smart hub 2.  Most are from early 2019.
Is it really bad.  I need good speeds upstairs with x Box , Netflix etc upstairs and my wifi cameras or did a firmware patch it.
Whats your thoughts on it.  Should I stop install if its that bad.
