nickjh
Message 1 of 11
SNR Margin Reset - Line Training Request
Hi, I live a long way from the exchange but my line has previously connected at around 2Mbps but speed has been falling over the last few months and ended up only connecting at 0.5Mbps or less. I had been using an ASUS router connected to an extension socket. This setup often lost connection (I think primarilly down to the router) and this resulted in the SNR margin being increased to around 16dB - hence the low connection speed.
I have now got a new Home Hub 4 and this is connected directly to the master socket. This was received and plugged in yesterday. When it established connection it synced at 544kbps with a downstream SNR ratio of 15.10dB. I have not rebooted the router since connecting it up and it has not dropped a connection.
Now I have the new connection setup I think I need to request an SNR reset and go through the 10 days settling period as if this were a new line so I can get a decent connection speed again. Does anyone know how I can get this organised?
Thanks,
Nick
10 REPLIES 10
Message 2 of 11
Re: SNR Margin Reset - Line Training Request
Hi Nick,
Welcome to the BT Care forums. To request a line reset you will need to wait for one of the mod's to pick this up or one of the user's with "CL" next to their name to notify a mod about this.
Hope this helps.
SuperSajuuk
Message 3 of 11
The mods are taking about 5-6 days to respond to messages sent to them (excluding weekends), so you would be better off just waiting a bit longer and let the DLM reduce your noise margin over time. If you were to contact the mods, they may end up replying after DLM has done what it's intended to do.
imjolly
Message 4 of 11
you need to post your stats from your hub - troubleshooting then helpdesk.
before the mods will help with noise margin reset you need to show a stable internet conenction for 3+ days otherwise a manual reset will be wasted if your conenction is not stable.  if your connection continues to drop after reset then DLM will just put you back to square one and reset would have been pointless
nickjh
Message 5 of 11
Thanks everyone for your advice.
Helpdesk info from Home Hub as follows:
1. Product name:BT Home Hub
2. Serial number:+068534+NQ51970703
3. Firmware version:Software version 4.7.5.1.83.8.130.1.26 (Type A) Last updated 15/07/15
4. Board version:BT Hub 4A
5. ADSL uptime:0 days, 06:22:40
6. Bandwidth:448 / 544
7. Data sent/received:12.5 MB / 54.4 MB
8. Broadband username:bthomehub@btbroadband.com
9. BT Wi-fi:Yes
10. 2.4 GHz Wireless network/SSID:BTHub4-T8FH
11. 2.4 GHz Wireless connections:Disabled
12. 2.4 GHz Wireless security:WPA and WPA2
13. 2.4 GHz Wireless channel:Automatic (Smart Wireless)
14. 5 GHz Wireless network/SSID:BTHub4-T8FH
15. 5 GHz Wireless connections:Disabled
16. 5 GHz Wireless security:WPA2
17. 5 GHz Wireless channel:Automatic (Smart Wireless)
18. Firewall:Default
19. MAC Address:54:64:d9:19:1e:94
20. VPI/VCI:0 / 38
21. Modulation:G.992.1 Annex A
22. Latency type:Interleaved
23. Software variant:-
24. Boot loader:
Loking at this the connection re-set in the early hours of the morning for some reason. Please see log below:
04:43:52, 16 Jul. ( 137.500000) CWMP: session completed successfully
04:43:51, 16 Jul. ( 137.040000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
04:43:49, 16 Jul.
IN: BLOCK [15] Default policy (TCP [66.193.112.93]:443- > [86.178.190.77]:42489 on ppp0)
04:43:49, 16 Jul.
( 134.950000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
04:43:49, 16 Jul.
( 134.950000) CWMP: Session start now. Event code(s): '6 CONNECTION REQUEST,4 VALUE CHANGE'
04:43:49, 16 Jul. ( 134.510000) CWMP: session completed successfully
04:43:48, 16 Jul. ( 133.330000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
04:43:46, 16 Jul.
( 131.570000) CWMP: Initializing transaction for event code 6 CONNECTION REQUEST
04:43:46, 16 Jul. ( 131.540000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
04:43:46, 16 Jul.
( 131.540000) CWMP: Session start now. Event code(s): '6 CONNECTION REQUEST,4 VALUE CHANGE'
04:43:45, 16 Jul.
( 131.100000) CWMP: Initializing transaction for event code 6 CONNECTION REQUEST
04:43:43, 16 Jul.
IN: BLOCK [15] Default policy (TCP [66.193.112.93]:443- > [86.178.190.77]:56095 on ppp0)
04:43:43, 16 Jul. ( 128.580000) CWMP: session completed successfully
04:43:42, 16 Jul.
IN: BLOCK [15] Default policy (TCP [66.193.112.93]:443- > [86.178.190.77]:51230 on ppp0)
04:43:42, 16 Jul. ( 128.020000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
04:43:39, 16 Jul.
( 124.390000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
04:43:39, 16 Jul.
( 124.380000) CWMP: Session start now. Event code(s): '1 BOOT,M Reboot,4 VALUE CHANGE'
04:43:17, 16 Jul.
IN: BLOCK [15] Default policy (TCP [222.186.30.82]:6000- > [86.178.190.77]:3306 on ppp0)
04:43:16, 16 Jul. BLOCKED 3 more packets (because of Packet invalid in connection)
04:43:14, 16 Jul.
OUT: BLOCK [9] Packet invalid in connection (Invalid tcp flags for current tcp state: TCP [172.16.0.68]:49628- >[17.134.62.236]:443 on ppp0)
04:43:11, 16 Jul.
OUT: BLOCK [9] Packet invalid in connection (Invalid tcp flags for current tcp state: TCP [172.16.0.68]:49626- >[17.134.63.169]:443 on ppp0)
04:43:09, 16 Jul. BLOCKED 1 more packets (because of Default policy)
03:42:28, 16 Jul. ( 85.010000) PPP IPCP Receive Configuration ACK
03:42:28, 16 Jul. ( 84.820000) PPP IPCP Send Configuration Request
03:42:28, 16 Jul. ( 84.820000) PPP IPCP Receive Configuration NAK
03:42:26, 16 Jul. ( 83.330000) PPP IPCP Send Configuration ACK
03:42:26, 16 Jul. ( 83.320000) PPP IPCP Receive Configuration Request
03:42:26, 16 Jul. ( 82.820000) PPP IPCP Send Configuration Request
03:42:26, 16 Jul. ( 82.820000) WAN operating mode is DSL
03:42:26, 16 Jul. ( 82.820000) Last WAN operating mode was DSL
03:42:25, 16 Jul. ( 81.490000) PPPoA is up - VPI: 0, VCI:38
03:42:25, 16 Jul. ( 81.480000) CHAP authentication successful
03:42:24, 16 Jul. ( 81.340000) CHAP Receive Challenge
03:42:24, 16 Jul. ( 81.340000) Starting CHAP authentication with peer
03:42:24, 16 Jul. ( 81.330000) PPP LCP Receive Configuration ACK
03:42:24, 16 Jul. ( 81.310000) PPP LCP Send Configuration Request
03:42:24, 16 Jul. ( 81.310000) PPP LCP Receive Configuration Reject
03:42:24, 16 Jul. ( 81.310000) PPP LCP Send Configuration ACK
03:42:24, 16 Jul. ( 81.310000) PPP LCP Receive Configuration Request
03:42:24, 16 Jul. ( 81.250000) PPP LCP Send Configuration Request
03:42:21, 16 Jul. ( 78.320000) ETHoA is up - VPI: 0, VCI:35
03:42:21, 16 Jul. ( 78.320000) DSL is up
03:42:20, 16 Jul. ( 77.370000) DSL noise margin: 9.00 dB upstream, 15.00 dB downstream
03:42:20, 16 Jul. ( 77.300000) DSL line rate: 448 Kbps upstream, 544 Kbps downstream
03:41:44, 16 Jul. ( 40.450000) WAN Auto- sensing running.
04:41:14, 16 Jul. (116801.000000) PPP LCP Send Termination Request [User request]
03:42:37, 16 Jul. ( 93.940000) CWMP: session closed due to error: WGET TLS error
( 89.110000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user:
03:42:32, 16 Jul. ACS username
03:42:32, 16 Jul.
( 89.110000) CWMP: Session start now. Event code(s): '1 BOOT,M Reboot,4 VALUE CHANGE'
03:42:23, 16 Jul. ( 79.650000) CWMP: session closed due to error: No response
03:42:23, 16 Jul.
( 79.630000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
03:42:23, 16 Jul.
( 79.620000) CWMP: Session start now. Event code(s): '1 BOOT,M Reboot,4 VALUE CHANGE'
03:41:51, 16 Jul. ( 47.610000) CWMP: session closed due to error: No response
03:41:46, 16 Jul.
( 42.840000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
03:41:46, 16 Jul.
( 42.830000) CWMP: Session start now. Event code(s): '1 BOOT,M Reboot,4 VALUE CHANGE'
03:41:46, 16 Jul. ( 42.550000) CWMP: Initializing transaction for event code 1 BOOT
04:41:13, 16 Jul. (116799.780000) CWMP: session completed successfully
03:41:47, 16 Jul. STP Alert: Port eth0 leaving blocking state.
04:41:13, 16 Jul. (116799.780000) The system is going DOWN for reboot.
04:41:11, 16 Jul. (116797.460000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
04:41:08, 16 Jul.
(116794.750000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
04:41:08, 16 Jul.
(116794.750000) CWMP: Session start now. Event code(s): '6 CONNECTION REQUEST,4 VALUE CHANGE'
04:41:08, 16 Jul.
(116794.430000) CWMP: Initializing transaction for event code 6 CONNECTION REQUEST
03:42:37, 16 Jul.
IN: BLOCK [15] Default policy (TCP [66.193.112.93]:443- > [86.178.190.77]:44697 on ppp0)
03:42:32, 16 Jul.
OUT: BLOCK [15] Default policy (First packet in connection is not a SYN packet: TCP [172.16.0.68]:53878- >[194.132.162.229]:4070 on ppp0)
03:42:32, 16 Jul.
OUT: BLOCK [65] First packet is Invalid (Packet not in tcp window: TCP [172.16.0.68]:1048- >[194.132.198.116]:4070 on ppp0)
04:19:52, 16 Jul.
IN: BLOCK [16] Remote administration (ICMP type 8 code 0 195.251.255.69- >86.168.235.13 on ppp0)
04:19:15, 16 Jul.
IN: BLOCK [16] Remote administration (TCP 199.203.59.121:3714- >86.168.235.13:22 on ppp0)
03:54:45, 16 Jul.
OUT: BLOCK [65] First packet is Invalid (TCP 172.16.0.68:4071- >17.110.230.18:5223 on ppp0)
03:52:57, 16 Jul.
IN: BLOCK [16] Remote administration (ICMP type 8 code 0 203.178.148.19- >86.168.235.13 on ppp0)
03:48:42, 16 Jul.
IN: BLOCK [16] Remote administration (ICMP type 8 code 0 129.82.138.44- >86.168.235.13 on ppp0)
03:44:21, 16 Jul.
IN: BLOCK [16] Remote administration (TCP 184.105.247.240:55008- >86.168.235.13:443 on ppp0)
03:44:18, 16 Jul.
IN: BLOCK [16] Remote administration (TCP 221.203.3.117:48625- >86.168.235.13:22 on ppp0)
03:42:37, 16 Jul. ( 94.230000) NTP synchronization success!
03:42:34, 16 Jul. ( 90.660000) NTP synchronization start
03:41:51, 16 Jul.
( 47.880000) Lease for IP 172.16.0.68 renewed by host udhcp- 1- 17- 4- 54- a0- 50- 6e- d1- 68 (MAC 54:a0:50:6e:d1:68). Lease duration: 1440 min
( 47.870000) Device connected: Hostname: udhcp- 1- 17- 4- 54- a0- 50- 6e- d1- 68 IP: 03:41:51, 16 Jul. 172.16.0.68 MAC: 54:a0:50:6e:d1:68 Lease time: 1440 min. Link rate: 100.0
Mbps
03:41:51, 16 Jul. ( 47.810000) Lease requested
03:41:46, 16 Jul. ( 42.850000) Wire Lan Port 1 up
03:41:43, 16 Jul. ( 39.710000) System up, firmware version: 4.7.5.1.83.8.130.1.26 (Type A)
03:41:36, 16 Jul. ( 32.910000) System start TR069
03:33:56, 16 Jul.
IN: BLOCK [16] Remote administration (TCP 62.75.236.76:40518- >86.168.235.13:22 on ppp0)
03:12:02, 16 Jul.
IN: BLOCK [16] Remote administration (ICMP type 8 code 0 206.117.25.90- >86.168.235.13 on ppp0)
02:27:24, 16 Jul.
OUT: BLOCK [65] First packet is Invalid (TCP 172.16.0.68:51987-
>65.20.0.43:993 on ppp0)
03:41:43, 16 Jul.
03:41:36, 16 Jul.
03:33:56, 16 Jul.
03:12:02, 16 Jul.
I can see some login stuff from BT here but not sure if that's what caused the connection to re-set. Any ideas?
If I leave everything alone do you think my connection speed will automatically improve over time?
Thanks for your help,
Nick
imjolly
Message 6 of 11
if you leave the conenction conencted to test socket with new filter then your noise margin should reduce and speed increase over time provided connection remains stable.  if it keeps dropping then you need to find the cause as your conenction nspeed will not improve without a stable conenction
if you can get 3+ days connection time then repost your stats and we can see if mods will help you and reset your mnoise margin
nickjh
Message 7 of 11
Hi Guys,
Router connection now seems very stable. Since I connected the New Home Hub direct to the Master Socket last week the connection has dropped twice - Once when the router rebooted to do a firmware update and once when I did a manual reset to try and get a faster sync speed (it made no difference). Connction has run for over 4 days (since I did the manual reset). Sync speed is only 512kpbs and SNR margin is 15.2 dB.
Is it possible to get the mods to initiate an SNR reset or will my line automatically increase speed and, if so when?
Thanks.
Router stats below:
1. Product name: BT Home Hub
2. Serial number: +068534+NQ51970703
3. Firmware version: Software version 4.7.5.1.83.8.130.1.26 (Type A) Last updated 15/07/15
4. Board version: BT Hub 4A
5. ADSL uptime: 4 days, 06:42:55
6. Bandwidth: 448 / 512
7. Data sent/received: 453.4 MB / 1.6 GB
8. Broadband username: bthomehub@btbroadband.com
9. BT Wi-fi: Yes
10. 2.4 GHz Wireless network/SSID: BTHub4-T8FH
11. 2.4 GHz Wireless connections: Disabled
12. 2.4 GHz Wireless security: WPA and WPA2
13. 2.4 GHz Wireless channel: Automatic (Smart Wireless)
14. 5 GHz Wireless network/SSID: BTHub4-T8FH
15. 5 GHz Wireless connections: Disabled
16. 5 GHz Wireless security: WPA2
17. 5 GHz Wireless channel: Automatic (Smart Wireless)
18. Firewall: Default
19. MAC Address: 54:64:d9:19:1e:94
20. VPI/VCI: 0 / 38
21. Modulation: G.992.1 Annex A
22. Latency type: Interleaved
23. Software variant: -
24. Boot loader: -
imjolly
Message 8 of 11
as you now have a stable conenction the mods will help and reset your noise margin
After completing the email NOT PM then you join a queue of other customers waiting for mod help. The mods will get back to you in 3/5 working days either by phone or email
nickjh
Message 9 of 11
Thanks,
How do I get in touch with the Mods?
imjolly
Message 10 of 11
they will post herewith invite to the contact us link
