P1LTS
Message 1 of 11
SNR Margin Reset Request
i recently moved house and due to the layout of the house, I was initially unable to use the master socket for my HH4 confection.  Unfortunately, the use of the internal house extension caused regulate line drops. I have now resolved the issues and the HH4 is now connected to the master socket and the line has been stable for a good number of days. However, the NOISE MARGIN  appears stuck at12db.
Could I please request a reset back to 6db to see if I can increase my synch speed.
( 82.830000) DSL noise margin: 25.00 dB upstream, 12.00 dB downstream
( 82.760000) DSL line rate: 448 Kbps upstream, 6176 Kbps downstream
10 REPLIES 10
Webby
Message 2 of 11
Re: SNR Margin Reset Request
Once the connection has been stable for 3-5 days, DLM should automatically reduce the target margin. Leave it for a week and then try a reboot. If that makes no difference then post back.
P1LTS
Message 3 of 11
Hi Webby.
I left it for 7days with the noise margin at 12dB. I then rebooted the router, but it resynched with the same noise margin. It has been the same now for 5days.
The connection is now rock solid, just at a higher than ideal noise margin.
Webby
Message 4 of 11
Have you called the helpdesk and requested an SNR reset?
P1LTS
Message 5 of 11
No. I didnt realise you could do that. Do you have a contact no.
imjolly
Message 6 of 11
it would have helped if you had included the date on the 2 lines of stats to show length of connection time  help desk
08001114567
  Faults  0330 123 4567
P1LTS
Message 7 of 11
Well I cantacted the helpdesk and after being redircected a couple of times, I spoke to a gent whom is arranging for the target SNR to be reset.
Let's hope this sorts things out.
imjolly
Message 8 of 11
if nothing happens then post back and we can see if mods will help you
DavidM
Moderator
Moderator
Message 9 of 11
Hi @P1LTS,
Thanks for posting. If the reset order is placed today you should see a difference within 48 hours but if you don't post back as @imjolly has mentioned and we'll pick up for you.
Cheers
David
P1LTS
Message 10 of 11
Hi All
It looks as if the SNR reset has been carried out. The noise margin is now reporting as 6.1dB.
The synch speed has increased to 7680kBps. The BT sppedtester is reporting an IP profile of 6.5Mbps
My actual spped is quite slow at present but I was told to expect this whilst the line re-trains.
I'll see how it goes over the next few days.
