Message 1 of 15
SNR Margin variations
My SNR Margin varies on a day to day basis from 11db down to 8db, it's usually lower when weather is wet.
As it goes down to 8db I assume that my BRAS is set to 6db and I am getting 2 to 5db of noise and that this will explain why I get resynchronisations at roughly 10 day intervals ?
However BT quiet line is silent, so Openreach are not going to look at this for me.
Am I making the right assumptions ?
14 REPLIES 14
Message 2 of 15
Re: SNR Margin variations
noise margins do fluctuate over 24hrs - higher in mid morning to late afternoon and then dropping to low point probably about 11pm and then starting to increase again back to high at midday and then cycle starts again.  this is due to line noise/interference as the lines get busy particularly after dinner time when people start using the phone lines.
can you post your adsl stats as noise margin is maybe higher then normal due to line problems and errors report may show that.
are you connected to the master of test socket?
Message 3 of 15
As at 1830 tonight.
> show adsl
 Version=                                        119
 DspFirmwareVersion=                             Y.1.28.187
 DSPVersion=                                     0x00000050
 Connected=                                      True
 OperationalMode=                                G.Dmt
 State=                                          Showtime
 Watchdog=                                       0x00000053
 OperationProgress=                              0x000000AD
 LastFailed=                       8.5 dB
 LocalLineAttn=                                  37.5 dB
 LocalTxPower=                &nbRate=                                      6304000
 TxCellRate=                                     1056
 RxCellRate=                                     14867
 PhyTXCellCount=                                 1880694
 PhyRXsp;                                 0x0000006B
 TxBitRate=                                      448000
 RxBitbsp;                            0
 LocalITUCountryCode=                            0x0000B5FF
 LocalSEF=                                       0
 LocalEndLOS=                                    0
 LocalSNRMargin=             &nbCellCount=                                 8711596
 PhyCellDropCount=                               0
 OverallFailure=    &nsp;                  12.1 dB
 LocalFastChannelRxRate=                         0
 LocalFastChannelTxRate=                         0
 LocalFastChannelFEC=                            0
 LocalFastChannelCRC=                            0
 LocalFastChannelHEC=           p;          0
 RemoteFastChannelHEC=                           0
 RemoteFastChannelNCD=                           0
 RemoteInterleavedChp;   0
 LocalInterleavedChannelRxRate=                  6304000
 LocalInterleavedChannelTxRate=                  448000
 LocalInterleavedChannelFEC=                     22893
 LocalInterleavedChannelCRC=                     18823
 LocalInterleavedChannelHEC=                     17341
 LocalInterleavedChannelNCD=                                    0
 LocalFastChannelNCD=                            0
 LocalFastChannelOCD=                                                          87
 RemoteLineAttn=                                 19.0 dB
 RemoteSNRMargin=                                21 dB
 RemoteFastChannelFEC=                           0
 RemoteFastChannelCRC=                &nbs  0
 LocalInterleavedChannelOCD=                     2
 RemoteSEF=                                      67
 RemoteLOS=    &nbsannelFEC=                    2180
 RemoteInterleavedChannelCRC=                    0
 RemoteInterleavedChannelHEC=                    65
 RemoteInterleavedChannelNCD=                    57
 LocalMgmtFEC0=                                  0
 LocalMgmtCRC0=                                  0
 LocalMgmtFECErroredSec=                         0
 LocalMgmtErroredSec=                            0
 LocalMgmtSeverelyErroredSec=                    0
 LocalMgmtLOSErroredSec=                         0
 LocalMgmtUnavailErroredSec=                     0
 LocalMgmtHEC0=                                  0
 RemoteMgmtFEC0=                                 0
 RemoteMgmtCRC0=&np;       0
 LocalTPSTCCell0UpperLayer=                      0
 LocalTPSTCBitError=                             0
 RemoteTPSTCCell0=     &nbspnbsp;              0
 RemoteMgmtSeverelyErroredSec=                   0
 RemoteMgmtLOSErroredSec=                        0
 RemoteMgmtUnavailErroredSec=                    0
 RemoteMgmtHEC0=                                 0
 LocalTPSTCCell0=                        &nbsbsp;                                0
 RemoteMgmtFECErroredSec=                        0
 RemoteMgmtErroredSec=            &;                         0
 RemoteTPSTCCell0UpperLayer=                     0
 RemoteTPSTCBitError=                            0
 SRA=                                            Disable
 PSDMask=                                        Standard
Message 4 of 15
Part two:
ActivateLine=                                   None
HostControl=                                    Enable
AutoStart=                                      True
Failsafe=                                       False
Action= Startup
Standard=                                       G.Dmt
UtopiaInterface=                                Level1
EcFdmMode=                                      FDM
MaxBitsPerBin=                                  15
TxStartBin=                                     6
TxEndBin=           &nbnbsp;                       Disable
NTRMode=                                        Disable
AnnexType=         &nbnbsp;                            255
RxAutoBinAdjust=                                Disable
TxAttenuation=                                  0.0 dB
BitSwap=                                        Enable
BitSwapUp=              &;                         Disable
Capability=                                     A
CodingGain=                                        AnnexA
MaxDownRate=                                    4095
PhysicalPort=                                   0
Retrain=                                        Enable
DetectNoise=                                    Disable
Capability=                                     A
CodingGain=                                     auto
FramerType=                                     Type3
DyingGasp=                                      Disable
Defaults=                                       None
Message 5 of 15
from what you have posted you are on adslmax up to 8mb and have a 6mb connection with noise margin of 8.5db.  I couldn't see the connection time.
if you have a connection time of 3+ days then I would contact the mods and get noise marghin reset to 6 which will give you an increase in speed
can you run btspeedtester and post the results please
Message 6 of 15
My Router has been on line for 625 hours and the PPPoA has been connected for 161 hours.
Download Speed 3470 Kbps
DSL Connection Rate 6304 Kbps / 488 Kpbs
IP Profile 5500 Kpbs
Message 7 of 15
hi your ip profile is correct for your connection speed
Message 8 of 15
Ironic, but between 5 and 6am this morning the system resynchronised itself!
I'm now connected at 5312000 / 448000, SNRM is now 13.5 db.
Am I right in suspecting noise or other interference is the likely cause?
As I say above quiet line test is silent.
Line is directly to master socket, there's no internal wiring, (telephone is DECT on the only filter).
Frustrating, as I cannot see Openreach accepting a fault.
Message 9 of 15
yes you have a noise issue try connecting to the test socket to eliminate any internal problems
Message 10 of 15
Makes no difference.
There's no internal wires from the master socket.
