Good to know about annexM. Here is my stats
adslctl: ADSL driver and PHY status
Status: Showtime
Last Retrain Reason: 0
Last initialization procedure status: 0
Max: Upstream rate = 1504 Kbps, Downstream rate = 21916 Kbps
Bearer: 0, Upstream rate = 828 Kbps, Downstream rate = 19232 Kbps
Link Power State: L0
Mode: ADSL2+
TPS-TC: ATM Mode
Trellis: U:ON /D:ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 5.9 9.2
Attn(dB): 14.5 8.0
Pwr(dBm): 20.9 12.2
ADSL2 framing
Bearer 0
MSGc: 57 24
B: 154 34
M: 1 2
T: 4 2
R: 14 16
S: 0.2575 2.6667
L: 5251 258
😧 96 8
Counters
Bearer 0
SF: 364014 295260
SFErr: 0 2
RS: 91731269 267890
RSCorr: 3895 437
RSUnCorr: 0 0
Bearer 0
HEC: 26 1
OCD: 3 0
LCD: 3 0
Total Cells: 617348839 11525642
Data Cells: 52842908 1731544
Drop Cells: 0
Bit Errors: 0 265
ES: 0 2
SES: 0 0
UAS: 115 115
AS: 5905
Bearer 0
INP: 1.00 1.50
INPRein: 0.00 0.00
delay: 6 5
PER: 16.22 20.00
OR: 31.07 12.00
AgR: 19189.06 836.73
Bitswap: 34/34 37/37
The Bold/Underline is my issue. This in INTERLEAVED (6ms downstream) and just wanted to go back to a FAST latency,
interleaved is normally only applied if there are/have been conenction problems - have you had connection problems the internet connection time is missing from stats
if your line is still not stable then getting mods to reset latency to fast will only be short lived as the disconnections will result in DLM changing latency back to interleaved to try and stabilise the line need to find cause of disconnections then get latency changed
did you try quiet line test see if any line noise?
adsl2 can sometimes cause problems on longer lines when upgraded but you are almost on top of the exchange with these connection speeds
have you tried using the test socket with filter instead of master and see if that helps stability as I said unless line is stable then if mods reset latency to fast then DLM would just move to interleaved if disconnections continued
