imjolly
Message 11 of 16
Re: SNR Reset and AnnexM
that's ok what you are trying to get is a stable connection for at least 3+ days as without stable connection any resetting of latency is pointless
rackstraw1208
Message 12 of 16
ok its been a few days with a slight change but still no fast latency..
Last initialization procedure status:   0
Max:    Upstream rate = 1556 Kbps, Downstream rate = 24100 Kbps
Bearer: 0, Upstream rate = 828 Kbps, Downstream rate = 20991 Kbps
Link Power State:       L0
Mode:                   ADSL2+
TPS-TC:                 ATM Mode
Trellis:                U:ON /D:ON
Line Status:            No Defect
Training Status:        Showtime
                Down            Up
SNR (dB):        2.7             11.5
Attn(dB):        14.5            8.1
Pwr(dBm):        20.8            12.2
                        ADSL2 framing
                        Bearer 0
MSGc:           36              24
B:              114             34
M:              1               2
T:              6               2
R:              12              16
S:              0.1751          2.6667
L:              5804            258
D:              128             8
                        Counters
                        Bearer 0
SF:             15872564                363792
SFErr:          157             7
RS:             3999886125              578997
RSCorr:         97863391                16571
RSUnCorr:       514             0
                        Bearer 0
HEC:            270             0
OCD:            0               0
LCD:            0               0
Total Cells:    76478109                341837535
Data Cells:     1385667094              74124578
Drop Cells:     0
Bit Errors:     0               240
ES:             152             7
SES:            0               0
UAS:            0               0
AS:             175042
                        Bearer 0
INP:            1.00            1.50
INPRein:        0.00            0.00
delay:          6               5
PER:            11.02           20.00
OR:             30.46           12.00
AgR:            20940.56        836.73
Bitswap:        43924/43924             739/739
As you can see the latency increased to a depth of 128 now and the SNR dropped to under 3. So now will someone be able to change me back to a FAST profile.
imjolly
Message 13 of 16
your stats don't show any internet connection time
if interleaved depth has now increased then there is problem with your conenction so much so that DLM has increased your latency to try a stablise your conenction  it may be the 2.7db noise margin is to low and needs to be higher or there are problems with your line and noise
rackstraw1208
Message 14 of 16
58:18:47 That's what the connect time is now.. about 46 hours ago that's when I noticed the increase in depth and lower snr. Should the default snr not be 6?
imjolly
Message 15 of 16
the  standard default noise margin is 6db but many adsl2 conenction have the 3db as normal giving a bit more connection speed  however in some cases the lower noise margin causes instability an better going back to 6db and sacrificing a bit of connection speed for better stability
is that time system up time not internet connection time which is often lower due to drops in conenction
rackstraw1208
Message 16 of 16
No it is connection time. My connection may be faster but it's takes ages for web pages to load. The only benefit is when downloading but for everyday browsing it's just pants.
