Moderator
Moderator
Message 11 of 14
Re: SNR Reset
Hi @Gremlin10 and thanks for posting.
I can appreciate how frustrating this is for you and am happy to lend a hand. Can you send me over your details using the contact link in my profile? Once I have them I'll take a look at this for you. We're very busy at present so it's taking longer than expected to reply but once you submit the details we'll get to you in turn.
Cheers
David
Moderator
Moderator
Message 12 of 14
Re: SNR Reset
Hi @Gremlin10,
Thank you for sending in your details. I've carried out an SNR reset on your line. You should start to see an improvement over the next few hours. I'll get back in touch with you tomorrow evening to see how your connection is preforming.
PaddyB
Message 13 of 14
Re: SNR Reset
Cheers Paddy,
          It literally happened a 5 or so minutes after you sent that last message.
It's working perfectly now.
Thank you. 🙂
Moderator
Moderator
Message 14 of 14
Re: SNR Reset
Great result @Gremlin10. Thanks for letting us know it's all sorted.
Cheers
David
