Message 1 of 56
SNR fluctuation and banded after line upgrade
Hi,
I have recently been upgraded to ADSL2+. I only found out after checking dslchecker coincidentally on the exact day that the order was due to be completed (09-Jan-2018). I didn’t request the upgrade but it was a welcome surprise!
A day after the upgrade I saw a nice increase on download/upload speeds - 4.14 Down/ 0.70 Up with a higher attainable rate!
At the time, there was no mention of what modulation I had been upgraded to and I couldn’t see it anywhere in my router stats ( Billion 7800DXL) or on the BT email notification. So I stupidly unplugged the Billion and plugged in a HomeHub 4 to find I had been upgraded from ADSL1 (G.992.1) to ADSL2+ (G.992.5). I disconnected the Homehub and reconnected the Billion which was working before.
I instantly got a reduced line rate at 3070/828 and the SNR was fluctuating a lot more than normal. On the Billion 7800DXL router I've always had a SNR reduction in place to lower by 2dB so all figures are inclusive of this tweak. During the day, the downstream SNR would be fairly stable at around 6-8dB, at around 6pm it would decrease to 3-4dB and then at 9pm it would then hit -0.2dB which would force the router to disconnect for a good 5-10 mins. The router would then reconnect and sync at a higher SNR.
After a couple of days of this SNR fluctuation and disconnects, I think I have now been banded at 2Mbps downstream
I’ve been monitoring my line since and my SNR fluctuates from 0.5-8dB but I haven’t seen it hit negative figures again. Here are some SNR graphs to illustrate the fluctuations:
I have performed a quiet line test which is sounding nice and clear.
The router isn’t connected to the test socket but is connected to the master socket.
Through research, I discovered REIN, but if the router disconnects because of low SNR and then reconnects at a higher SNR with no major degradation after that, would that suggest electrical interference isn’t the issue?
I’m not sure what’s physically involved in upgrading lines but could it be a wire/connection issue from the switch over at the cabinet?
I have left the router alone with the hope of achieving 10-14 days uptime but so far it’s only reached 4 days and then reset with no change.
Here are my current stats with an uptime of 1 day 5:10
xDSL
Mode
ADSL_2
Traffic Type
ATM
Status
Up
Link Power State
L0
Downstream
Upstream
Line Coding (Trellis)
On
On
SNR Margin (dB)
7.8
7.3
Attenuation (dB)
36.5
22.1
Output Power (dBm)
19.1
12.2
Attainable Rate (Kbps)
6176
1324
Rate (Kbps)
2270
828
K (number of bytes in DMT frame)
0
0
R (number of check bytes in RS code word)
0
0
S (RS code word size in DMT frame)
0
0
D (interleaver depth)
160
8
Delay (msec)
7
5
INP (DMT symbol)
7.50
1.50
Super Frames
42936319
24367401
Super Frame Errors
5891
1768
RS Words
2187224103
1365619
RS Correctable Errors
9967305
47325
RS Uncorrectable Errors
10237
0
HEC Errors
11327
2853
OCD Errors
34
0
LCD Errors
34
0
Total Cells
526168566
191888649
Data Cells
349622122
23385919
Bit Errors
0
40288
Total ES
609
349
Total SES
61
30
Total UAS
132
102
I hope someone can advise.
Thanks in advance.
55 REPLIES 55
Message 2 of 56
Re: SNR fluctuation and banded after line upgrade
I would try moving to the test socket with a filter and see if that helps as you have a lot of errors in the stats  adsl2 can be less stable than adslmax on longer lines so what was ok on adslmax may not be on adsl2
the banded profile normally releases automatically in 3/5 days stable connection but any drops in that perios and the timescale starts again
Message 3 of 56
Thanks @imjolly
I connected the router to the test socket yesterday and will leave it connected there.
The SNR didn’t drop below 2dB yesterday evening but I’ll keep monitoring.
Is it normal for the SNR to fluctuate as much as it has (-0.2db-8dB)? Do you think this will improve when the router has a longer uptime and the line is seen as more stable?
Also, regarding the automatic banding release, I had an uptime of approx 4 days 5 hours before the line dropped. Do you think I could have been close to being released from this profile?
Message 4 of 56
that is a a huge noise margin fluctuartion and not normal   hopefully it will be better in test socket
if now in test socket with filter can you post stats from your router for comparison to previous stats.
if you have extension sockets in other rooms have you checked that there are 'dead' with no dial tone
Message 5 of 56
@imjolly
That’s what I thought and I can’t say I’ve noticed it to this extreme before. So far today the downstream margin has been around 8-9dB and the upstream around 2-3dB. But I usually see a decline in the downstream from around 4pm. The upstream has just this minute increased to around 8dB.
I’ve just double checked the extensions and they are completely silent with no dial tone.
Here are my current stats:
Line Rate - Upstream (Kbps)
828
Line Rate - Downstream (Kbps)
2270
Connection Time
21:18:18
xDSL
Mode
ADSL_2
Traffic Type
ATM
Status
Up
Link Power State
L0
Downstream
Upstream
On
On
SNR Margin (dB)
8.9
7.9
Attenuation (dB)
36.5
21.9
Output Power (dBm)
19.2
12.2
6004
1332
Rate (Kbps)
2270
828
0
0
0
0
0
0
160
8
Delay (msec)
7
5
INP (DMT symbol)
7.00
1.50
Super Frames
50689209
28707442
Super Frame Errors
7754
1921
RS Words
1708396006
3454384
1850913
21274
35814
0
HEC Errors
15371
3097
OCD Errors
101
0
LCD Errors
101
0
Total Cells
410971509
149877779
Data Cells
119208392
10287755
Bit Errors
0
14949
Total ES
1117
426
Total SES
71
30
Total UAS
180
140
Message 6 of 56
now nee to stay in test socket if possible andsee if line stays stble and the noise margin fluctuation are not as extreme as before.  you are in a banded profile which hopefully will relent if sable and you can get the 6mb speed
can you try the quiet line test make sure there is no line noise
Message 7 of 56
Thanks @imjolly
I'll make sure to stay connected to the test socket and keep monitoring the line for noise fluctuations. The downstream is now 6dB and the upstream is 8dB
Fingers crossed it stays stable and the banded profile gets lifted because it would be nice to hit that 6Mbps mark! That's double what I'm used to on ADSLmax!
I've been trying the quiet line test at all different times of the day since the fluctuations began but it's showing the line to be crystal clear. Just double checked again now and it's all clear.
Message 8 of 56
that's good hopefully it stays clear and just keeep checking the noise margin
Message 9 of 56
Hi,
I’ve now been connected for 5 days 16 hours, however, the banded profile doesn’t seem to be shifting.
My SNR seems to be higher in comparison to before, which I assume is part of training. The downstream seems to fluctuate between 6.5dB - 13dB. Does this still seem a little extreme? The upstream seems more stable at 9.2dB with a few dips here and there. Here are some graphs to illustrate the SNR range:
28/01
29/01
30/01
Here are my router stats too:
732
2270
Connection Time
5 Day(s) 16:13:07
xDSL
Mode
ADSL_2
Traffic Type
ATM
Status
Up
Link Power State
L0
Downstream
Upstream
On
On
SNR Margin (dB)
11.9
9.1
Attenuation (dB)
36.0
21.7
Output Power (dBm)
19.0
12.2
6088
1164
Rate (Kbps)
2270
732
0
0
0
0
0
0
160
8
Delay (msec)
7
5
INP (DMT symbol)
6.00
2.00
Super Frames
43321586
24252653
Super Frame Errors
593
498
RS Words
2327104796
1180125
1920016
15684
15172
0
HEC Errors
2753
619
OCD Errors
41
0
LCD Errors
41
0
Total Cells
2626264183
846655495
Data Cells
598752830
62276853
Bit Errors
0
73931
Total ES
269
230
Total SES
0
2
Total UAS
23
23
Message 10 of 56
still big fluctuations in noise margin  is quiet line test quiet when connected to the filter in test socket?
