Message 1 of 4
SSE works triggered DLM?
Hi All
Wondering if anyone can help? I was plodding along nicely with a 72 meg sync speed until last weekend. SSE posted a notice through my door saying they needed to replace a 3 wooden poles up tbe road from me which would require power to be turned on and off several times. It turned put to be roughly 11 times as they were testing everyones supply.
Anyways. My question is roughly how long does DLM deem a stable time frame?
3 REPLIES 3
Message 2 of 4
Re: SSE works triggered DLM?
It can but not necessarily will take a few weeks.
Message 3 of 4
@gg30340 thank you I will just leave it on
Message 4 of 4
Provided you now have a stable connection it should start recovering incrementally over the next couple of weeks.
Leaving it on is the best way, restarts will only prolong the issue.
