Message 1 of 2
Samknows
Hi,
Is anyone else on here participating in the samknows speed test on BT Infinity?  i have my whilebox plugged in and the speed is all over the place.  Average speed is 42.32mb when it should be 74mb really...
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: Samknows
Hi @NachoHeeledge,
Welcome to the community forum.
Can you run the BT Speed test using the link - http://speedtest.btwholesale.com/
You'll need to run that using a wired connection. Once the first test completes, please run the "further diagnostics" as this will show the profile set for your line.
Once you have run that test, please post back the results.
PaddyB
