Sharpy74
Message 1 of 8
Samsung Galaxy S3 on Openzone with BT Wifi App - Can't load search results error
When my phone is connected to Openzone using the BT Wifi app and I go to the Google Search widget and search for a term, I get the error "Can't load search results". When I then click the "Images" or "News" button (rather than Web) the search results load fine. For some reason Web search isn't working when connected to Openzone. Works fine on 3G and normal private Wifi hotspots.
7 REPLIES 7
CraigS
Moderator-Retired
Message 2 of 8
Re: Samsung Galaxy S3 on Openzone with BT Wifi App - Can't load search results error
Hi sharpy74
If you connect to BT Wifi wihout using the app does it work ok?
Cheers
Craig
BTCare Community Mod
If we have asked you to email us with your details, please make sure you are logged in to the forum, otherwise you will not be able to see our ‘Contact Us’ link within our profiles.
We are sorry but we are unable to deal with service/account queries via the private message(PM) function so please don't PM your account info, we need to deal with this via our email account :-)”
td-p/30">Ratings star on the left-hand side of the post.
Sharpy74
Message 3 of 8
if I force stop the app and retry I see the same symptoms.
richarddstarky
Message 4 of 8
I get exactly the same problem when using BT WiFi openzone or btwifi with fon etc , my device is a nexus 4 and I'm using the btwifi app too .
Haven't tried without app yet but I will next time and report back .
jaywright
Message 5 of 8
I was getting same 'can't lead search results' error. hadn't thought to check without Wi-Fi until reading this thread. Wi-Fi disconnected and results indeed load fine
jaywright
Message 6 of 8
Update, checked home Wi-Fi and this works fine. Looking like it's the btwifi!
Sharpy74
Message 7 of 8
I'm still having the same problem
zoot478
Message 8 of 8
Same issue on S3
