Help us improve our customer experience. We are very keen to get your thoughts on some of the ideas we are exploring. Please take a few minutes to complete this short survey,
@gg30340 wrote:
You can say Amazon, Argos, ebay or any other retailer. It is just links to them that you can not post on the forum..
Did not want to appear to be promoting one shop over another, they all have their good and bad points
So you only want to promote companies whose name starts with an A
"I have seen them priced at £44.99 just now, at a shop beginning with A."
@icclebug wrote:
Typically rooms not next to each other. Seen refurbed for £44 but be better if I can return if they don’t do the job.
You would not be able to use them if you have existing powerline adapters. Did you use those on the Panasonic TV issue in May?
Maplin are doing the BTWifi Homehotspot 500 triple kit for £35.
EDIT: It looks like they might be out of stock on line but your local shop may still have them.
@icclebug wrote:
No Keith, I managed to use a wired connection, all been good since.
Can you use them plugged into extension cables?
If they are just the normal short unfiltered multi way adapters, but not a long extension reel, or surge protected sockets.
There are never enough sockets in a room, especially for children, teenagers etc
@icclebug wrote:
Oh yes, kids!
It’s just a 4 way 10 amp extension lead, 2m I think.
Normally no problem with those.
