alanhj
Message 1 of 3
Saving E-Mails
I want to be able to save without copying and pasting some of my important e-mails. It would be really good to be able to save e-mails that I have placed in a folder, simply by "saving" that folder to say a USB memory stick. There maybe a way of doing this but I can't find out how to do it. So, if I'm right and currently this feature doesn't exist, do other people on here think its a good idea and if it is possible to save as described above, please tell me. Thanks
2 REPLIES 2
Message 2 of 3
Re: Saving E-Mails
Reply is in next posting.
Message 3 of 3
Re: Saving E-Mails
Because you access your e-mail using an Internet browser, it is not possible to save the contents of the folders using that method.
The way to do it, is to use an e-mail client like Mozilla Thunderbird, which runs on your computer.
This replicates the folders on your local computer. From there you can archive any e-mails or even a whole folder.
Thunderbird works very well with BT Yahoo, and you can write and reply to e-mails on either Thunderbird, or the normal webmail.
If you need any help, please let me know.
Here is a picture of what it looks like. This is a image from another site.
