Message 1 of 3
Says Sim Deactivated but isn’t
I recently upgraded my sim from the 15GB plan to the 40GB plan. However after doing so when I go onto the BT app to check my data usage it comes up with this... ‘The selected SIM is no longer active, and there is no usage. Select a different SIM.’
Also comes up with this on the website too. Very annoying as Dont know how much data ive used.
2 REPLIES 2
Message 2 of 3
Re: Says Sim Deactivated but isn’t
Hi @dbrbb, try calling 0800 800 150, I wouldn't bother using live chat. I had the same message and that's how I finally got it resiolved.
Message 3 of 3
Hi @dbrbb
As @Andy005 suggested try giving the mobile team a call or speak to the Mobile Online Chat Team, if you need any help after pop back and let us know..
