gotogmca
Message 1 of 3
Scam Call
Just to warn you that there is a scam call going around asking you to select 1 or 2 otherwise your broadband connection will be disconnected.  Tel number dialling in is 02044688479.  Just hang up!
2 REPLIES 2
NeilO
Moderator
Moderator
Message 2 of 3
Re: Scam Call
Hi @gotogmca you done the right thing by hanging up. To help us fight these fraudsters you can now  report scam calls on this link.
Andy_N
Distinguished Guru
Message 3 of 3
Re: Scam Call
Hi, welcome to the forums.
As it happens, this particular scam has been around for many, many months. Scammers tend not to call the same number more than once (unless they get some form of result), hence the call can seem to be new.
The scammers use VoIP technology and spoof the calling from number - hence is not real and can't be blocked. However in this case the whole of 020 4x range has not been released by OFCOM, so there is a possibility of it being blocked for now.
