TimSmedley
Message 1 of 4
Scrolling back in time more than 24 hours
Hi
YouView box in and working for two weeks with all going well. We are now gradually learning the new functionality & differences between this and a Vision Box with no surprises or disappointments so far.
One small thing to clarify is with the EPG and scrolling back the 7 days to watch/download programmes. It only seems to want to go back to 4 AM this morning and prior to that on all channels states "No information". I understood we should be able to go back 7 days?
I've turned it off & on and rebooted the hub (much to the irritation of the Broadband I fear!) but to no avail.
Any suggestions?
Tim
Tags (2)
3 REPLIES 3
drhowells
Recognised Expert
Message 2 of 4
Re: Scrolling back in time more than 24 hours
This isn't the answer you want, but I have had the problem once before, I rebooted the box and it seemed to clear the problem. Can you try restarting just the box once more and see what happens?
TimSmedley
Message 3 of 4
Booted the box & hub and all working well now! Many thanks. Tim
drhowells
Recognised Expert
Message 4 of 4
Glad it worked 🙂
