Message 1 of 3
Search emails by date
Hi
Can I search for emails across all my folders by date, and if so how do I do it please ?
Thanks  Jeff S
2 REPLIES 2
Message 2 of 3
Re: Search emails by date
Click on the search box down arrow the right side of the search box.
This will open a drop down box with various options.
In the "Folder" field select "All Folders" then in the "From Date" select the date you want to search from and in the "To Date" select the dat you want to search up to. Then click "Search.
Message 3 of 3
Brilliant - thanks so much !
