Message 1 of 5
Security camera image storage
Can I plug a USB HDD into the smart hub 2 and use it to store video from a (non BT) security camera?
4 REPLIES 4
Message 2 of 5
Re: Security camera image storage
Yes, you can just map it as an network drive letter.
Map it to //192.168.1.254/usb1
Message 3 of 5
You can't write to it directly like a NAS though it will need to be via a PC.
Message 4 of 5
Thanks for your reply.  R
Message 5 of 5
