Newbie
Message 1 of 2
Sending a message to multiple recipients
I want to send the same e mail to everyone in my contacts list, Is there any way of selecting all my contacts or do i have to check the box next to everyones name in order to achieve this?
Regards Peter
1 REPLY 1
Message 2 of 2
Re: Sending a message to multiple recipients
You can not select all contacts. You will need to select them one at a time and add them to the email. If you do this on a regular basis you could set up a Group Contact and drag your contacts into that group.
You can not have more than 49 contacts in your list or the message will not send.
