baldrick69
Message 1 of 10
Sending mail via FOSCAM IP camera
If anyone, anywhere, has ever got this working, please would you give me the magic settings.
I have a couple of Foscam IP cameras which have the ability to email out when motion is detected.  I have had this working by using my Exchange 2010 server at work - but we've just upgraded to Exchange 2013 - it no longer works.
When it worked with the work email server I had to use the IP address (yes, whatever DNS server I used - my home hub IP, BT's DNS servers, even Google's).  However, it did work so I know it's possible.
I've tried:
SMTP server:  mail.btconnect.com, 213.123.26.152
SMTP Port: 25, 465, 587
Needs authentication: Yes
SMTP username: myname@btinternet.com, myname
It would be nice to use a Google's SMTP through BT but I understand that's yet another BT restriction.
Using mail.btconnect.com on port 465, returns "cannot connect to mail.btconnect.com, port 465: Connection refused".
Same with port 25.
Any ideas?
9 REPLIES 9
gg30340
Message 2 of 10
Re: Sending mail via FOSCAM IP camera
This is a BT Residential Forum. If you are a business user you should post on the BT Business forum https://business.forums.bt.com/ where you may get some help.
baldrick69
Message 3 of 10
I am BT home user.  This is home user question.
gg30340
Message 4 of 10
The reason I asked was because you are using mail.btconnect.com as your server where I would have expected a residential user to use mail.btinternet.com
Keith_Beddoe
Message 5 of 10
That is almost certainly the problem, you cannot send from a residential account, using a BT Business Broadband SMTP server.
baldrick69
Message 6 of 10
Thanks for pointing that out - I hadn't realised the distinction.
However,  the error message changes ever so slightly to:
cannot connect to mail.btinternet.com, port 465: Connection refused
baldrick69
Message 7 of 10
Update:
Using the following settings seems to work:
SMTP server: 65.20.0.43 (lord knows why but I can't persuade it to use a DNS server)
SMTP Port: 587
TLS: None
Authenication: Yes
Many thanks to those who replied.
Keith_Beddoe
Message 8 of 10
I have a Foscam camera which sends from a Gmail account without any issues.
For BT Mail, its would be
mail.btinternet.com
port 465
normal password
SSL/TLS
Remenbering to enter your e-mail address and password.
Those settings should work fine, from a BT Residential Broadband connection.
baldrick69
Message 9 of 10
What do you use for a DNS server - IP address of your home hub??
I'm completely puzzled as to why the Foscam doesn't seem to resolve host names.
Keith_Beddoe
Message 10 of 10
I use the home hub DNS, as its at my parent`s house, however I had to uninstall BT Parental controls, as the Foscam camera tries to use Google`s public DNS, which causes it to fail, as BT Parental controls block other DNS servers.
