wasleys
Message 1 of 5
Sequence when powering down router
My router is usually on all the time but when I'm away for some time I power down the router and remove the ADSL cable from the wall socket (ADSL v1.0 if it matters).
I seem to remember reading somewhere that it was better to do one of these before the other as that would help to give a better speed on return. I can't re,
4 REPLIES 4
Message 2 of 5
Re: Sequence when powering down router
doing what you are is ok no problems
Message 3 of 5
There's no need to do either in reality. If you want to power the hub down there's no need to unplug the ADSL cable. Just turn it off at the wall
wasleys
Message 4 of 5
Thanks for responses.
Message 5 of 5
Glad to help any time
