richardj
Message 1 of 3
Series linking on a G4 BOX
Hi can anyone help. I am unable to series link cycling events on Eurosport. The older style Youview box worked fine. Unfortunately this developed a fault so had to be changed for a G4 Box .
       thanks Richardj
2 REPLIES 2
gomezz
Recognised Expert
Message 2 of 3
Re: Series linking on a G4 BOX
How are you selecting a programme to be recorded?
Most likely explanation is that Eurosport has cocked up the series linking. Can you give a specific example of a programme that you think should be series linked but isn't for us to try?
richardj
Message 3 of 3
Thanks for your response Gomezz.
I access the recording function via the red record button and the guide. The problem was with recording the Criterium du Dauphine, no series link option was offered. I had to record each day individually. I had no problem with the Giro d'itallia.
Yesterday I tried to series link the Tour of Switzerland and The Route du Sud, the latter I could, the former not. Today it has reversed !!! I think your right about Eurosports arbitary linking. It's just a little frustrating though !
Thanks again for your comments.
