StewNich
Message 1 of 6
Session selector on online player
Does anybody know how to hide the session selector bar when in full screen mode when using the online player? Or is it possible to watch online player in standard rather than the enhanced player?
It’s really annoying because it hides the score bar but it’s fine when not in full screen mode.
5 REPLIES 5
gomezz
Recognised Expert
Message 2 of 6
Re: Session selector on online player
Not sure what you mean? Which coverage on which device?
Have you tried just tapping the main part of the screen?
StewNich
Message 3 of 6
Streaming on a Windows 10 laptop using internet explorer on the BT website.
When you click full screen when watching the cricket a black “session selector” bar will remain at the bottom of the screen and if you want to go back to the start of a session you would click it. I feel it should really disappear when you enter full screen mode but irritatingly stays at the bottom of the screen blocking the match scores so was wondering if there was a way of disabling it at all?
gomezz
Recognised Expert
Message 4 of 6
Ah! See what you mean. Yes, it is annoying.
Another example showing that if you are going to let cool hipster web designer dudes loose on your sports site then you need to get their work reviewed by actual sports enthusiasts before allowing it out into the wider world.
zulu17
Distinguished Guru
Distinguished Guru
Message 5 of 6
Have you tried when in full screen mode moving the cursor  ... for example to the centre of the screen (ie away from the headers and footers) and then clicking.
StewNich
Message 6 of 6
Yep still just stays there
